43028-1002
- D3
43028-1002
21 Jul 2014 06:19
Can anyone help with a new KZ1000 mk11 front brake master cylinder diaphragm/ 43028-1002.
Also used on 1977 onwards KZ 400, 650 750 1000's with twin disc trapezoid type M/C.
Thankz in advance.
Thankz in advance.
[URL[/IMG][/URL]
- taildragger1197
Re: 43028-1002
14 Apr 2021 17:04
Bumped as I am in need of this discontinued part. Anyone have a lead on who may be selling these now. TIA
43028-1002
www.partzilla.com/catalog/kawasaki/motor...cylinder-79-80-b3-b4
43028-1002
Union City, Tennessee
1979 KZ1000 LTD B3
1979 KZ1000(1260)LTD S/G Pro ET
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
- Steel Legion
Re: 43028-1002
14 Apr 2021 17:44
The master cylinder and brake lever from a 2007 Kawasaki Ex650 has the same piston size as the '77 kz's with dual disc fronts. It should work the same as the '77 kz masters. I have one I just put on my '77 kz but I haven't had time to bleed my brakes and get it set up yet.
1977 Kz650c
The following user(s) said Thank You: taildragger1197
- Steel Legion
Re: 43028-1002
14 Apr 2021 17:50
I know it's not exactly what you are looking for, but it's a good modern solution to your problem.
1977 Kz650c
Re: 43028-1002
14 Apr 2021 19:17 - 14 Apr 2021 19:18
They are reproducing them. Give me a minute to find the site
EDIT.....
www.z-power.co.uk/master-cylinder-front-...angular-1978-onwards
EDIT.....
Last edit: 14 Apr 2021 19:18 by Mikaw.
- taildragger1197
Re: 43028-1002
14 Apr 2021 19:54 - 15 Apr 2021 10:56
Thanks for the quick replies but please note, all I need is the diaphragm, the rubber gasket under the cap.
My M/C is fine and I don't want to buy a new one just for that gasket. Anybody ?
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
Last edit: 15 Apr 2021 10:56 by taildragger1197.
- Steel Legion
Re: 43028-1002
14 Apr 2021 20:33
Ahhh, I see. Well too bad you don't have the old round cup style(one of the worst looking mc's I've seen) because have my old rubber diaphragm from it still and it's in great condition. But good luck on your search!
1977 Kz650c
Re: 43028-1002
15 Apr 2021 06:56
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationHad to buy used to get what I needed.
Got the slave rebuild kit new.
Re: 43028-1002
17 Apr 2021 20:31
- taildragger1197
Re: 43028-1002
18 Apr 2021 00:05
Yes! Thank you very much! I have a lead on a good used M/C and, If it doesn't work out, I'll get this.
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
1979 KZ1000 LTD B3
1993 ZX11 D1 Ninja
