Where to find a shorer speedo cable?
  • kzz1king
  • kzz1king's Avatar Topic Author
18 Jul 2014 17:02
#640542
I am looking for little shorter speedo cable. Lowered the gauges a little. . Also, is there a difference in the size of the lower ferrule between the Z1 and the KZ's? I have some spare cables around but the ferrule housing is larger than my speedometer drive.
Wayne
Home built KZ1000 turbo setup
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Where to find a shorer speedo cable?
18 Jul 2014 17:21
#640546
Maybe check out a z1r cable.
  • bluej58
  • bluej58's Avatar
19 Jul 2014 05:28
#640576
I have a shorter cable somewhere that I bought by mistake for my 1000 and you can have it for free.
What length do you need?
78 KZ1000 A2A
  • kzz1king
19 Jul 2014 19:43
#640656
The cable I have is 36" end to end of the housing itself. Thanks
Wayne
  • kzz1king
19 Jul 2014 19:46
#640657
Thanks, that cable is 32.5 " end to end. I will have to do some mocking up to see.
Wayne
PLUMMEN wrote: Maybe check out a z1r cable.
  • bluej58
  • bluej58's Avatar
20 Jul 2014 18:03 - 20 Jul 2014 18:05
#640739
I'm not sure how you measured the housing but the cable I have measures 34.125 inches tip to tip of the inside cable
JD
78 KZ1000 A2A
Last edit: 20 Jul 2014 18:05 by bluej58.
  • kzz1king
20 Jul 2014 19:10
#640748
I measured the outside ,not the inner cable. Oustside was 36" and I think the inside is (cable itself) is about 38.
Wayne
