Need some input on building a seat.
  • kzz1king
  • kzz1king's Avatar Topic Author
13 Jul 2014 19:42
#639982
I need to find someone to build aseat for this pan I built. I would like to have the seat made i such a way that it could be velcroed unto the pan. I am thinking a 1/4 in plywood base. I am concerned about a material buildup between the bottom of the seat and the pan creating an unsightly gap. Looking for words of wisdom from those that have been there.
My pan.
Attachment DSCN3162.jpg not found
What I would like seat to look like, It could be a 2 piece with the butt pad being seperate.
Attachment motorcycle_monkee_36_1.jpg not found
THANKS
Wayne
Home built KZ1000 turbo setup
  • ramtough_63
  • ramtough_63's Avatar
Re: Need some input on building a seat.
13 Jul 2014 20:48
#639986
don't know if this helps but couple ways to eliminate the gap that could be created use a thin base (I/4' plywood)
procure a 1 " thick piece of closed cell foam ( easy to sand shape doesn't break apart or desintegrate) hollow it out the thickness of your board glue it to your board add another 1" piece of jhigh density foam to it mould surface as desired
have cover sewn to desired pleating leaving boxing long (side panels) stretch tight staple to board towards center
as far from edges a reasonable Having the boxing sewn at all 4 corners will eliminate the bunching on the corners that is present when stretching vinyl on corners
use T nuts in the plywood to fasten seat to pan 3or 4 per side would =be fine for bottom back may require 4
make sure the T nuts are close enough to edge that when the pan is tightened down it it pushes slightly against the closed cell foam as to not leave ant gaps
Attachment 1XGH6_AS01.jpg not found
T Nut
similar to the way we used to make padded panels in boats
1978 KZ1000 A2
Facebook Page
Free Range Custom Art
1982/83 750R/GPZ
1984 Goldwing 1200 Interstate
1982 Yamahopper QT50
Previous
2 79 HD sporty XLH
02 HD FLSTS Heritage
60's HD Hummer
70's Honda 550 Four
70 Yamaha 100
  • kzz1king
14 Jul 2014 07:49
#640017
That does help Ram.Is the reson for the closed cell foam to allow it to compress more tightly against the seat pan? By closed cell are you referring to the blue, yellow or pink board commonly used for building insulation?
Thanks.
Wayne
ramtough_63 wrote: don't know if this helps but couple ways to eliminate the gap that could be created use a thin base (I/4' plywood)
T Nut
  • kzz1king
14 Jul 2014 07:52
#640018
For further clarification, Layers from top down would be:
High density foam
closed cell foam board
plywood.
