ohlins fork
  • boyracer
  • boyracer's Avatar Topic Author
ohlins fork
09 Jul 2014 21:20
#639532
I have come across a set of ohlins forks off a 2004 999 ducati. Doesn't 'appear' to be crash damaged.
I ASSUME they're 43mm's? Haven't been to see them yet.
Anyway.
Potential pitfalls...
Too short?
Pin/bearings are very large diameter- i assume i can turn up a replacement to suit and use Z bearings.
Possible clearance issues around headstock or body work.
Spring rates- 999 weighs < 200 kg, the Z1R, ahem, slightly more. At least they'd be fully tunable.
Going on my '77 Z1R.
I'll run a vernier over them and report back. I haven't done my due diligence searching yet but thought someone might of tried this one before?
  • 531blackbanshee
  • 531blackbanshee's Avatar
  • Vendor
  • Vendor
Re: ohlins fork
10 Jul 2014 07:36
#639555
no help on those particular forks.but typically most are shorter and yes you may have tank interference issues that may have you modify the stops.
hth,
can't wait for you to report back.
  • boyracer
Re: ohlins fork
15 Jul 2014 23:49
#640222
They turned out to be Showas, missing bottom clamp and most def' crash damaged so i left it at that. I'll keep looking.
  • 531blackbanshee
  • Vendor
  • Vendor
Re: ohlins fork
16 Jul 2014 05:39
#640235
prolly best.
  • steell
  • steell's Avatar
Re: ohlins fork
16 Jul 2014 22:01
#640334
The Showa Big Piston forks are supposed to work really well, if you can find any. 2004-05 ZX12R has gold upside down forks with radial brakes, and compression, rebound, and preload adjustable. And they are fairly long, I think they are around 29".
