Tire Size
  • shauntexas
  • shauntexas's Avatar Topic Author
Tire Size
02 Jul 2014 08:38
#638670
Hello Yall,
I have a 77' Kz 1000 - (with mags) using the original swing arm.. could someone tell me what the largest REAR tire I can use..
Thanks
  • StreetfighterKz
  • StreetfighterKz's Avatar
Re: Tire Size
02 Jul 2014 09:51
#638679
Normally one size bigger than stock is ok. But really you'll only be 10mm wider or just 5mm (3/16") per side. Not enough to give a "fat tire" look.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
The following user(s) said Thank You: PLUMMEN
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
Re: Tire Size
08 Jul 2014 07:28
#639249
Doug I too have a stock 77' KZ1000A that you've been helping as well as others in putting it back together again. Haven't got around to selecting the tires and sizes yet, but what would you recommend? I've used both Bridgestone Battlax Bt-45's and Avon Roadriders before on other bikes and have liked the results.
77' KZ1000A
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Tire Size
08 Jul 2014 07:44
#639255
Google is your friend here. This is what I found regarding your question regarding wheel/tire sizes
  • kzdcw
  • kzdcw's Avatar
  • 77' KZ1000A
Re: Tire Size
08 Jul 2014 07:57
#639258
Slayer61, Do you know what is the stock rim width of these wire wheels on my KZ?
77' KZ1000A
  • PLUMMEN
  • PLUMMEN's Avatar
Re: Tire Size
08 Jul 2014 08:43
#639263
A 4.00 or a 120mm should be pretty close to tire that came stock on a wire wheel.
Anything wider than a 130 will have a really weird tread profile on that rim.
  • slayer61
  • slayer61's Avatar
Re: Tire Size
08 Jul 2014 09:11
#639266
kzdcw wrote: Slayer61, Do you know what is the stock rim width of these wire wheels on my KZ?
Your wheel "should" have the size engraved in it somewhere. Have a look around the entire rim and it will tell you what size it is.
  • StreetfighterKz
Re: Tire Size
08 Jul 2014 09:26 - 08 Jul 2014 09:27
#639269
Something makes me think the stock front is 1.85" and the rear is 2.15".
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
Last edit: 08 Jul 2014 09:27 by StreetfighterKz.
  • StreetfighterKz
Re: Tire Size
08 Jul 2014 09:28
#639270
Just checked Z1Enterprises. Those are the sizes listed for reproduction rims.
Later, Doug
1979 z650 Resto-Mod
2018 Z900RS
  • Hemified
  • Hemified's Avatar
Re: Tire Size
08 Jul 2014 11:23
#639286
On my 1976 kz900 I run perelli sport demons they are great 120/90-18 rear 100/90-19 front. Oh yeah I do run stock width spoked rims.
