Shaft drive ratios
  • DGA
  • DGA's Avatar Topic Author
Shaft drive ratios
02 Jul 2014 08:33
#638668
Hi, trying to find out the gear ratios for the early '80s KZ shaft drive bikes. If anyone knew the either reduction ratio or the driver/ driven tooth count in the final drive unit, that would be great, thanks!
"83 KZ1100 Spectre, '81 Yamaha XV750 Cafe, '74 Kawasaki H2B 750
  • DGA
Re: Shaft drive ratios
08 Jul 2014 14:52
#639325
Awwm 34 views and no replies. Anyone there have a spare shaft drive rear end they could turn over and check for me? Put a mark on the wheel spline and turn the input shaft and count the turns until the wheel spline has done one full revolution. If it takes 3 revolutions to one wheel revolutions then it is 3:1 etc. Please, someone?
  • peter1958
  • peter1958's Avatar
08 Jul 2014 15:19
#639330
www.gearingcommander.com/ I dont know if they have your bike but they have my 1300 shaft
08 Jul 2014 16:26
#639335
I can't say for sure, but it might help get some replies if you stated which model you are talking about. There were at least a dozen early 80's shaft drive KZ models. Ed
KZ1300-A2 (1980)
KZ1300-A3 (1981)
KZ1300-A4 (1982)
KZ1300-B2 (1980)
KZ1100-A1 (Shaft) (1981)
KZ1100-A2 (Shaft) (1982)
KZ1100-A3 (Shaft) (1983)
KZ1100-L1 (LTD Shaft) (1983)
KZ1000-E2 (Shaft) (1980)
KZ750-F1 (LTD Shaft) (1983)
KZ550-M1 (LTD Shaft) (1983)
KZ550-F2 (LTD Shaft) (1984)
  • PLUMMEN
  • PLUMMEN's Avatar
08 Jul 2014 16:34
#639338
Are you trying to change the gear ratio?
It would probably be easier to run a shorter or taller tire depending on which way youre trying to go.
  • Nebr_Rex
  • Nebr_Rex's Avatar
08 Jul 2014 18:23
#639354
I have yet to see an alternate radio for a shaft drive KZ.
Original poster; what are you trying g to accomplish?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
The following user(s) said Thank You: PLUMMEN
  • DGA
08 Jul 2014 20:42
#639383
Im actually trying to find a lower numerical rear end gear for a Yamaha Virago. I have an '80 KZ750 E but it's a chain bike so no good there. The Viragos have low gearing from when the speed limit was 55 mph and there is no other taller gear for them, so was hoping a KZ rear end could be adapted in.
  • PLUMMEN
  • PLUMMEN's Avatar
08 Jul 2014 20:58
#639387
Try a taller tire :)
  • DGA
09 Jul 2014 09:29
#639425
Already am there with the taller tire, Virago has a 16" rear wheel, the Seca has the exact same wheel style and shaft drive but is an 18", this gave me a 10% RPM decrease at the same speed. The rear exhaust comes out between the swingarm and tire so had to cut and move that forward. There is a taller 5th gear from a late model Vstar but don't want to have to split the engine to put that in, so was looking for something a little less work.
  • oldzed
  • oldzed's Avatar
09 Jul 2014 12:15
#639449
would a non USA version have different gearing?
If so what about Ebay in Europe.
  • PLUMMEN
  • PLUMMEN's Avatar
09 Jul 2014 12:17
#639451
What size is the 18" tire you have on there?
