Fork Leg Swap and Rear Mount Caliper?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
25 Jun 2014 18:43
#638002
I have a 77' KZ1000A and have been working diligently reviving an abandoned non-running soul. Able to free up the master cylinders and getting them work again. The front brake caliper is frozen but am thinking about purchasing a 78' and later caliper to mount it on the back side of the fork legs instead of the front. I understand to do this is to just swap outer fork legs around to get the mounting lugs to face the rear of the bike? Is this correct and all I would have to do is find the right caliper? I want to run stainless brake lines directly to the caliper.
77' KZ1000A
  • kzdcw
  • 77' KZ1000A
Re: Fork Leg Swap and Rear Mount Caliper?
26 Jun 2014 20:13
#638095
Anyone on the forum like to challenge this question? Appreciate any input to point me in the right direction.
77' KZ1000A
  • StreetfighterKz
  • StreetfighterKz's Avatar
26 Jun 2014 21:05
#638103
Swap the fork legs side to side. Then just buy a left caliper from a '78 Kz1000 or even some 650/750's for the left side. Also behind the chrome cover on the right side of the rim should be 4 tapped holes in case you want to add a second brake rotor.
Later,Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
  • kzdcw
  • 77' KZ1000A
27 Jun 2014 03:55
#638119
Doug, That's kind of what I thought by just looking at my bike. Anyone have a good used LH caliper for sale?
77' KZ1000A
  • kaw-a-holic
  • kaw-a-holic's Avatar
27 Jun 2014 17:17
#638179
You will also have to change the brake mater cylinder, to one for dual disk. I believe its a 5/8 bore?
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
  • kzdcw
  • 77' KZ1000A
27 Jun 2014 17:21
#638180
I'm just going to run 1 disk. Should be able to get by with the same master cylinder don't you think? It will be like a 78' KZ1000A2.
77' KZ1000A
  • PLUMMEN
  • PLUMMEN's Avatar
27 Jun 2014 18:38
#638187
You can use the same mastercylinder.
