Stainless Steel Barke LInes ( F ) ?
  • kzdcw
  • kzdcw's Avatar Topic Author
  • 77' KZ1000A
18 Jun 2014 09:49
#637070
Do they make F/R stainless brake lines for the 77' KZ1000? Like to get rid of the hard line going to the front caliper.
77' KZ1000A
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: Stainless Steel Barke LInes ( F ) ?
18 Jun 2014 09:56
#637071
Yes
  • 9er rider
  • 9er rider's Avatar
  • Keep a cool tool
18 Jun 2014 11:13
#637081
Im changing to later B model calipers so the stainless wrapped hoses go all the way to the calipers from the splitter alleviating the tubes and inline connections.
  • kzdcw
  • 77' KZ1000A
18 Jun 2014 15:04
#637106
I'm assuming to do this, one would need to rotate the fork tubes from the left to the right and right to left to get the caliper mounts facing the rear? Then look for a left hand side rear mount caliper?
77' KZ1000A
  • pete greek1
  • pete greek1's Avatar
18 Jun 2014 16:17
#637109
I'm not sure, but I think you can get adapters to fit your calipers and eliminate the hardlines, so you wont have to buy different calipers , ..maybe some one that's done it will chime in & save you some money
Pete
  • MFolks
  • MFolks's Avatar
18 Jun 2014 16:24
#637110
  • pete greek1
18 Jun 2014 16:40
#637114
And yes about switching fork tubes from left to right !!
Pete
  • 9er rider
  • Keep a cool tool
18 Jun 2014 17:32
#637122
when flipping the forks and adding another caliper all the hardware has to be correct as that it wont get into the rotors
  • kzdcw
  • 77' KZ1000A
18 Jun 2014 19:25
#637129
9er rider, Can you explain that better? Interested in doing this modification. Like to know what's all involved?
77' KZ1000A
  • 9er rider
  • Keep a cool tool
18 Jun 2014 22:01
#637137
specific mounting bolts are used for the calipers on different years and models. some are longer than others, soo be sure you check all mounting bolt clearances before hitting the trail
