Aftermarket 5/8" Rear Brake Master Cylinder
- kzdcw
- 77' KZ1000A
17 Jun 2014 09:26
Instead of rebuilding my 77' KZ1000A frozen rear master cylinder, Has "anyone" used any aftermarket 5/8" rear master cylinders with the remote fluid reservoir that you see on ebay??? It's seems with a little fabrication they could work. The mounting holes ( 2" spacing ) appear to be the same as the original KZ master. I think the remote fluid reservoir could be mounted somewhere on the frame and the "stock" KZ brake pedal pushrod might be able to be used? Just a thought, and I'm sure someone on this forum has probably used these master cylinders.
77' KZ1000A
- weales
Re: Aftermarket 5/8" Rear Brake Master Cylinder
19 Jun 2014 17:16
If possible, best to stick to the original m/cyl setup - most parts are still available (except for the actual m/cyl and reservoir) I was able to "un-freeze" the rear M/Cyl on my '78 Z1-R which I think is identical to the one on '77 Z1000. I removed the circlip and stopper then got a suitable sized "ezy-out" (LH threaded tapered screw device) and carefully screwed this into the hollow part of the piston where the rod engages. I kept turning until the piston decided to let go. Replacement piston and hardware are available through Z1 Enterprises. Be careful not to damage the bore of the m/cyl or you'll be up for a new m/cyl or re-sleeve job. After I rebuilt and bled the rear brake system I found I had a seepage of fluid from where the reservoir and the m/cyl bdy meet. I had to replace an O-ring which sits on the inner circumference of the body of the m/cyl - this is not identified in the IPB but available from Jim at Redline Cycles in Skokie, ill. Hope this helps,
Bill.
Current Project
1968 Norton P11A Desert Sled
Other bike (and daily ride)
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
2004 Yamaha FZR 600
Previous Bikes
78 Z1-R (resto)
91 Zephyr 750
73 Mach IV (Resto)
78 Z1-R
78 Z1-R (stolen)
76 Z900
76 Z650
73 Mach IV
72 Mach III
- kzdcw
- 77' KZ1000A
19 Jun 2014 19:53
Weales, thanks for the advice. I did manage to remove the piston. Found a tap of similar I.D. of the rear hollow portion of the piston. Screwed tap in until it had a good bite. Then put opposite end of the tap in vise. And with block of wood and hammer, drove the master cylinder body off the piston assembly. A lot of crude, but cleaned well. Re-installed, seems to work freely with no leaks.
77' KZ1000A
- kaw-a-holic
19 Jun 2014 20:50
I have one off my 77 KZ1000a1 if you need it. Moves freely, no leaks, rebuilt it and took it off 6 months later when I changed to modern rear sets. PM me if you need it.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
