77 kz1000 speedometer drive
- DesertWizardB1
14 Jun 2014 16:04
My speedometer stopped working on my last ride. I pulled the cable out of the front wheel drive and if I spin it by hand the gauge works. I jacked up the front wheel and put the cable back in the speedometer drive and it makes a clicking noise when I turn the wheel by hand. Also the wheel wants to stop turning at certain times. I pulled off the drive assembly and took it apart. I did not see any bits of metal in the grease and the ring gear looks a little worn but is not missing any teeth. The pinion gear looks to be held in with a pin but it is in a blind hole so I can't drive it out. Does anyone know if these are repairable and if so do they still make these parts?
Thanks,
Len
Thanks,
Len
Len
77 KZ 1000 LTD Original Owner
- Beaner242
Re: 77 kz1000 speedometer drive
14 Jun 2014 16:12
Are you sure the cable isn't broken inside the housing?
1982 KZ1000K LTD Chopper
- DesertWizardB1
14 Jun 2014 16:28
I pulled the whole cable out of the housing and it is not broken. I think the problem is with the pinion gear but I can't get it out to look at it. I just checked on Kawasaki.com and the pinion gear is not available anymore
Len
- kaw-a-holic
14 Jun 2014 16:28
I have one from a 77 KZ 1000a1 it is my old front end. PM me if you need it.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
- kaw-a-holic
14 Jun 2014 16:28
The drive not the cable.
Jon
1977 KZ1000a1
Mesa, AZ
1977 KZ1000a1
Mesa, AZ
The following user(s) said Thank You: DesertWizardB1
- DesertWizardB1
14 Jun 2014 16:38
Thanks, I just PM'd you.
Len
