Inner Fork Tube
  • shauntexas
  • shauntexas's Avatar Topic Author
Inner Fork Tube
12 Jun 2014 21:16
#636412
What's the difference between Part Number 44013-1002 and Part Number 44013-037 .... I need to replace my tubes due to rust but I'm having a issue finding affordable replacements.. Can I use these tubes interchangeably??
Re: Inner Fork Tube
13 Jun 2014 04:03
#636429
I would not try to interchange them. What motorcycle model do you have? Part #44013-1002 is the tube for the 1979-1981 Police KZ1000; part #44013-037 is for the 1973-1977 Z1, KZ900, and KZ1000-A1. (see images below). The internal parts are different so I would expect the internal portion of the tube to be different too, plus the length will almost certainly be different. I definitely recommend getting the correct tube for the model you own because your life depends on the forks working correctly. Post the model and maybe someone can help find one. Ed
Attachment 00003_2014-06-13.jpg not found
Attachment 00004_2014-06-13.jpg not found
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
Re: Inner Fork Tube
13 Jun 2014 04:59 - 13 Jun 2014 05:01
#636433
I seem to remember the C models having a larger diameter fork tube...in additional to all that Ed mentioned. If you are looking for the tube for the Z1/KZ900/KZ1000 models, then I think it is available as an aftermarket.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
Last edit: 13 Jun 2014 05:01 by Mcdroid.
  • shauntexas
Re: Inner Fork Tube
02 Jul 2014 08:34
#638669
Thanks Yall,
I figured there were different.. just wanted to get some feedback... I may just have these re-chromed..
  • bluezbike
  • bluezbike's Avatar
Re: Inner Fork Tube
02 Jul 2014 11:38
#638687
If I remember correctly, in order to re-chrome something you need to first de-chrome it (then get rid of the rust)......and that changes the metal by making it more brittle, also too much going on and you will get some dimensional differences. As Ed mentioned I think that getting a new or good used set of forks is your best and safest bet. Post some pictures or at least what type of bike you have
79 KZ 1000 LTD
  • MDZ1rider
  • MDZ1rider's Avatar
Re: Inner Fork Tube
03 Jul 2014 09:14
#638811
Fork tubes are "hard chrome", like hydraulic cylinder shafts. It is a completely different process from cosmetic/protection chrome plate. You may be able to find a good hydraulic repair shop that could make you new tubes, but it's not going to be cheap. They can't be replated.
You might try calling the guys at Race Tech suspension (racetech.com). They've expanded into the vintage street market and they are very knowledgeable on any motorcycle suspension issue . If they don't have it, they may be able to point you in the right direction.
Good luck
The following user(s) said Thank You: bluezbike
  • pete greek1
  • pete greek1's Avatar
Re: Inner Fork Tube
03 Jul 2014 09:47
#638814
1980 KZ 1000 police complete fork tubes offer.ebay.com/ws/eBayISAPI.dll?BinConfi...ries&quantity=1&fb=1
Pete
Re: Inner Fork Tube
03 Jul 2014 09:51
#638815
Here's a place can help answer questions or maybe supply replacements. Ed
www.frankmain.qpg.com/
