KZ1100-A2 Shafty Fork Oil Level
- ntdrivers
12 Jun 2014 17:06
Reaching out to forum members, I've not been able to find any data on the fork oil levels for my 1982 KZ1100-A2 Shaft drive. Can someone refer me to a document somewhere with the relevant data?
- Motor Head
Re: KZ1100-A2 Shafty Fork Oil Level
12 Jun 2014 18:19
www.kawiworld.com/index.php?option=com_c...icle&id=77&Itemid=99
Click on the picture of the service manual, and download it. It should have all of your bikes info.
- ntdrivers
13 Jun 2014 07:32
I already have the manual, and it's for a chain drive and not the shaft. There are two oil levels mentioned, but both are for the KZ1000 only. There's no manual online for the KZ1100 shaft drive.
- Puffin
19 Jun 2014 03:44 - 19 Jun 2014 03:44
with the springs removed and forks extended you are looking for 470mm for the A model
KZ1000 J Long Term Owner
KZ1100
KZ1100 Spectre project
KZ1100
Last edit: 19 Jun 2014 03:44 by Puffin.
19 Jun 2014 06:01
The "two levels" mentioned are likely the result of prescribed volumes for dry vs wet refills.
With correct volume assured, may create a dip stick from a slender wooden dowel to show the correct fork oil level level in the future whereby levels may be correctly maintained with forks extended and without messy removal of springs.
