Kz 900 dual disk brakes
- Handcannon
10 Jun 2014 10:57
Do I have to swap front forks to add second disk brake to kz900 a-4. Looks like all the ones that have dual have the caliper behind the forks instead of in front like mine has now with single disk. Thanks for any help.
- 4TheKZ1000
Re: Kz 900 dual disk brakes
10 Jun 2014 11:02 - 10 Jun 2014 11:13
Well does your other fork tube have the bosses to mount the caliper?
On a kz1000, you can mount the caliper on top like yours or behind the fork by changing forks from one side to the other.
I have a LTD dual setup on mine.
Attachment powdercoat018600x800.jpg not found
Last edit: 10 Jun 2014 11:13 by 4TheKZ1000.
- Handcannon
10 Jun 2014 11:13
Ok I'm game but how do you bolt the front fender back on. Am I missing something?
- 4TheKZ1000
10 Jun 2014 11:15 - 10 Jun 2014 11:18
that's why you move the right complete fork to left side and left to right. the bosses move but you still have fender mounts in the right orientation.
NO your not loosing it, I corrected my post from turning fork tube to swapping entire fork.......sorry...... :blink:
Last edit: 10 Jun 2014 11:18 by 4TheKZ1000.
- Handcannon
- Handcannon
10 Jun 2014 14:09
Now that I have the install sorted out with the forks does anyone have any pictures of how the brackets that mount to the front fender bolts for the caliper lines and speedo cable should be placed. Also do I need a longer speedo cable or do I reroute it. It was running behind the left fork but now the caliper is in the way and so it is not long enough.
