82 k650 chain wheel swap with 82 kz440 belt?
- rboutin2
05 Jun 2014 07:21 - 05 Jun 2014 07:27
I found a really good deal on an 82 kz440 twin parts bike. It has the mag wheels we like more than the spoke wheels. The bike is a 400 twin. It has a belt drive setup. My wife's bike is a 82 kz650h2 chain drive. Would I be able to swap the wheels directly over? Would the piece that the sprocket/pulley mounts to with the rubber cushion under just come out and swap them and that's it? I've included a pic of the parts bike too.
Also, would it be possible to swap the belt drive stuff over too, and convert the kz650 to belt drive? , from a little research I've done it seems like I'd have to swap swingarms, which wouldn't be that big a deal.
Last edit: 05 Jun 2014 07:27 by rboutin2.
- rboutin2
Re: 82 k650 chain wheel swap with 82 kz440 belt?
05 Jun 2014 12:08
After some research,
here are the part numbers for the bikes
82 kz650 CSR:
Rear wheel bearings: 601B6303ZZ
Rear Axle: 41068-1086
Rear Axle spacer: 92027-1226
Front wheel bearings: 601B6302Z
Front Axle: 41068-1009
Front Axle Spacer: 92027-1225
82 KZ440D Belt
Rear Axle: 41068-1060
Rear Axle Spacer: 92027-1198
Front Wheel bearings: 601B6302Z
Front Axle: 41068-1099
Front Axle Spacer: 92027-1085
Hopefully this helps someone out in finding out if the wheel wills wap or not and if so, what bearing or parts i would need to accomplish it.
82 kz650 CSR:
82 KZ440D Belt
05 Jun 2014 14:21 - 05 Jun 2014 14:27
I could be wrong, but don't think the swap will work without some serious (expensive) modifications. The KZ650 hub is oriented for 6 hub segments and 6 sprocket bolts. The KZ440 is oriented for 4 hub segments and 4 pulley bolts. See diagrams below. Ed
Attachment 00004_2014-06-05-3.jpg not found
Attachment 00005_2014-06-05.jpg not found
Last edit: 05 Jun 2014 14:27 by 650ed.
05 Jun 2014 14:34 - 06 Jun 2014 05:50
Are NEW belts readily available? If so --- Are they affordable?
The 440 rear wheel is different from the 650-CSR.
Last edit: 06 Jun 2014 05:50 by martin_csr.
- KraZyRIDER
05 Jun 2014 14:55
...Come on, you guys should know by now that any project is doable.
...Just as long as you have enough time and money to [strike]waste[/strike] throw at it.
...Good [strike]Fortune[/strike] Luck! :whistle:
Mean Green Speed Machine!
1979 KZ 650-C3 (Cafe Project)
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
1982 GPz 750-R1
1981 GPz 1100-B1
2005 H-D XL1200C
2006 H-D XL1200C
05 Jun 2014 17:59
I've never heard of a 650 being converted to belt. My gut says no.
The output shaft on the transmission is probably different on the 650.
But ya never know sometimes. hee.
- Nebr_Rex
05 Jun 2014 20:32
The front sprockets do not interchange. Neither does the rear.
The chain offset is also closer to the bikes centerline on the 400/440.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- rboutin2
05 Jun 2014 21:30
Ok thanks a million guys!!! Now, any ideas on what years and models of the kz bikes have the mag wheels that ARE interchangeable without much hassle? She has a slight hop to the front wheel cuz it's out of round, and we both like the look of the mag wheels better, and have been wanting to swap them since we got the bike.
06 Jun 2014 03:47 - 06 Jun 2014 06:55
Are you sure it's the wheel & not the tire?
The 1983 KZ650-CSR has cast alloy wheels & they are a direct fit.
KZ550-Ltd wheels are a direct swap too - all you need are the wheels - everything else is the same.
The 550A Fr wheel is the same as the 550C (Ltd). There are a few other models that have the same Fr as well.
1981 KZ650-CSR w KZ550-Ltd wheels.
Last edit: 06 Jun 2014 06:55 by martin_csr.
- rboutin2
06 Jun 2014 07:07
Is there any specific year range for the 550s? Or does pretty much any 550 alloy wheel work?
06 Jun 2014 08:31 - 06 Jun 2014 08:32
80-83 550C 550A. The 550 GPz wheels might be different.
The 550 Shaft Fr wheel will probably work but not the Rr (not 100% sure, though).
The wheels on my bike above are from a 1980 550-Ltd --- direct swap & easy.
Last edit: 06 Jun 2014 08:32 by martin_csr.
