535 Conversion chain install question
  • Markovich
  • Markovich's Avatar Topic Author
01 Jun 2014 00:49
#634822
Hi everyone, I read through all the great information about converting from the old 630 chain to the 530 chain and have ordered the recommended set from Z1 Enterprises. I spend my waiting time going over the installation process and realized that I don't know where to set the rear wheel during the initial install. Do I move the wheel all the way forward in the slots or just half way? I figured coming to the forum would get me the best answer. Hope to get the parts on Monday. I think once this is done I will be able to take it out for a test run. Any help with this is appreciated indeed.
1990 KZ1000P, 72k miles, 10 years in storage, new, bars, tires, chain and sprockets, seat, carbs cleaned, police equipement removed.
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: 535 Conversion chain install question
01 Jun 2014 04:43 - 01 Jun 2014 04:47
#634830
This is a good question.
I see it like this. I want to be able to adjust the slack out of the chain as it stretches. If you have rear wheel to far back in the adjustment area of the swing arm as the chain stretches.....you will run out of room and not be able to adjust the slack out of the chain.
I would want to have rear wheel axle in the very center of swing arm axle travel. You will have maximum adjustment and never run out.
Attachment axle1.png not found
Last edit: 01 Jun 2014 04:47 by 4TheKZ1000.
  • Markovich
01 Jun 2014 08:50
#634859
I appreciate the quick response. I posted this in carb section late last night. Then I titled it 535 instead of 530. Man not as young as I used to be. Chomping at the bit as they say. Waiting, waiting. Wow, love the internet and KZR forum! Keith
  • ezrider714
  • ezrider714's Avatar
01 Jun 2014 17:38
#634935
The length of the chain is what will determine where the wheel ends up in the slots. :huh:
If I have a choice (feel like shortening a chain) I like mine towards the front of the slots to allow the maximum amount of adjustment, if you're in the center you are leaving half of the adjustment on the table.... :( .
78 KZ650SR Mine since 79
4-1 Mac Jet Hot coated since mid 80's
Dyna Coils
Saddlebags (I ain't skeered of going nowhere) :)
