Am i in for problems?
- jsnabbs
- 1981 kawiKZ440
29 May 2014 01:24
When installing the swing arm back onto the frame after the frame being powdercoated the diameter of the bolt hole was smaller(due to the coating) i really had to BEAT the bolt through, could i be in for problems due to the bearings in the swing arm perhaps being damaged? should i remove it and buff excess coating off the inside on the hole?
also had the same with the top shock absorber stubs, i buffed the coating off and bingo, no problem going on.
Leason learnt now, any others i come across i will remove excess powdercoating
Im just worried about the bearings, but it seems to move freely enough, but should i bother removing again?
TIME TO TRADE IN THE PEDALS FOR SOME POWER
- jsnabbs
- 1981 kawiKZ440
Re: Am i in for problems?
29 May 2014 01:38
Im thinking i should be ok as the bolt goes through the sleeve, and the sleeve to the bearings. so the interferance was between bolt and inside of guide hole.
what say you?
what say you?
- worior1
29 May 2014 02:28
why didnt you or whoever was doing the powdercoating just mask the area that didnt need any coating off? it seems like an error on the behalf of the painter. but yes removing the excess powdercoat is the proper way to go about this because if you just force the items in you run the risk of damaging something.
i would ream all the holes that require cleaning and use a tap on the threaded components.
The following user(s) said Thank You: PLUMMEN
- jsnabbs
- 1981 kawiKZ440
29 May 2014 02:53
yes they should have masked the holes, for all other holes that have the same problem i have this
www.dremeleurope.com/gb/en/ocs/image/ocs...th=405&maxheight=248
- 4TheKZ1000
29 May 2014 03:58
You need to watch these guys that do work on your bike and parts.
I really spent time getting to know my powder coater before he did my parts.
Even with conversations and explaining to him what to and not to do, there were minor mistakes.
I made him fix it.
I made him fix it.
- jsnabbs
- 1981 kawiKZ440
29 May 2014 05:22
Being my first project it wasnt something i thought about, leason lernt.
just hope the bearings are fine, anyone want to chime in about what they think i should do about them? leave it or take them out now while its still apart
- baldy110
29 May 2014 10:20
By beating the bolt throught he powder coating you probably flaked some of the coating off and shoved it into the swingarm bearings. I would remove the bolt then clean the bearings and the coating off the inside of the bolt holes.
29 May 2014 13:12
If the bearings were in place and not protected when the part was powder coated and cooked, and then you beat the pivot bolt though them with a hammer because the fit was too tight, I think the answer is pretty clear. They need to be replaced. Ed
- jsnabbs
- 1981 kawiKZ440
03 Jun 2014 10:50
New bearings with rubber seals on the way.
I love this site always takes away that second guessing of ones self, and put you on track
many thanks
many thanks
- peter1958
03 Jun 2014 12:05
You will want to clean the hole in the frame for the ground wire.
www.kzzone.com/
- jsnabbs
- 1981 kawiKZ440
03 Jun 2014 12:37peter1958 wrote: You will want to clean the hole in the frame for the ground wire.
Thanks for the heads up, where is it?
