Lowering fork on Z1000J3
- Mk2Rookie
23 May 2014 03:25
Hi! i recently installed Progressiv Suspension springs in my forks and left out the spacer just to see how low it would get, the height is now about right but the fork is waaay to soft.. So i guess that's what the spacer is for! But i will like to lower it around 50mm (2") internal and i know this has been covered several times on this forum on other bikes but it might my english or just that i have not found anything about the J/R forks. I've learned that some put a spacer in the damping rod which will keep the natural position of the tubes lover in the forks.. But should this be done with the recommended spacer in top of the tubes or should i only put spacers on the rods ?
Simon
Attachment 128.jpg not found
Simon
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: Lowering fork on Z1000J3
23 May 2014 08:53
This conversion is done regularly on flattrack bikes. Remove the length of spring from the top and add it back in under the damper rod.
- Mk2Rookie
23 May 2014 11:13
So what i cut from the spring i put under the rod ? Or do i cut a spacer in the same lenght as the part i cut from the spring ?
Simon
Simon
- slayer61
23 May 2014 11:42slayer61 wrote: This conversion is done regularly on flattrack bikes. Remove the length of spring from the top and add it back in under the damper rod.
Maybe this will help
The short section of spring on the bottom is a "top-out" spring. You have to have SOMETHING there that will absorb top out type of action
- Mk2Rookie
23 May 2014 15:51 - 23 May 2014 15:57
Thank you so much! It all makes sense to me now
A spacer on top of the rebound spring will lower the forks and pre-load the springs but it also blocks off the hole in the rod so it has to be a spring? Am i correct ?
Last edit: 23 May 2014 15:57 by Mk2Rookie.
