Brakes
  • eric77kz
  • eric77kz's Avatar Topic Author
Re: Brakes
23 May 2014 17:48
#633699
Also what would cause JUST the EDGE of the rotor to heat up like that? I used the front brakes on my short ride and they were cool to the touch.
77 KZ650 C
  • moneypit
  • moneypit's Avatar
Re: Brakes
23 May 2014 18:14
#633703
Chances are that the pads are still in contact with the rotor. It wouldn't need to be much to create enough friction to heat it up.
2-76 kz900
St Paul MN
The following user(s) said Thank You: PLUMMEN
  • eric77kz
Re: Brakes
24 May 2014 08:45
#633755
So... If I have zero compression on my rear brakes, it's a master cylinder issue right?? Solution is a rebuild kit?? What about the calipers?? Rebuild kit?? Maybe it's both causing problems, maybe it's just one of them??
77 KZ650 C
Re: Brakes
24 May 2014 10:44
#633765
It could be air in the brake line. Ed
  • eric77kz
Re: Brakes
25 May 2014 06:47
#633905
Ok. I have my real wheel off and calipers and m/cyl in hand(brought them with me so I could work from home!). What is the breakdown on these? What parts should I look for that would cause no pressure from m/cyl?
77 KZ650 C
  • eric77kz
Re: Brakes
25 May 2014 20:44
#633990
I have the master cyl apart and dont see anything that would cause a problem. Could the spring be wore out? Also the lever/shaft that gose inside to push the piston came out on its own when I removed the m/cyl from the bike. Is that normal?
77 KZ650 C
  • eric77kz
Re: Brakes
25 May 2014 21:11
#633993
I have the main bolts holding the calipers to the bracket out(after MUCH fighting) now there are rubber bushings inside. How do I remove the bracket without messing them up? I can't even get to the cals yet.
77 KZ650 C
Re: Brakes
26 May 2014 08:15
#634028
eric77kz wrote: I have the main bolts holding the calipers to the bracket out(after MUCH fighting) now there are rubber bushings inside. How do I remove the bracket without messing them up? I can't even get to the cals yet.
If the "rubber bushings" refer to dust shields part number 43052-005, they may be worn out and need to be replaced.
The area where the caliper floats along the bolts is supposed to stay clean.
Good Fortune! :)
The following user(s) said Thank You: PLUMMEN, eric77kz
  • eric77kz
Re: Brakes
26 May 2014 11:27 - 26 May 2014 11:36
#634039
Here is my M/Cyl and rear calipers broke down.I need new dust seals all around and new pad(s?) I could not get to the spring in the m/cyl, seems fine. Also why does my bracket say B2 on it??? Am I missing anything else?
77 KZ650 C
Last edit: 26 May 2014 11:36 by eric77kz.
  • eric77kz
Re: Brakes
26 May 2014 11:46
#634042
Also could I get a parts list breakdown for these? I have ALOT of ordering to do!
77 KZ650 C
Re: Brakes
26 May 2014 16:20
#634060
eric77kz wrote: Also could I get a parts list breakdown for these? I have ALOT of ordering to do!
Here's the list from Kawasaki.com. Ed
Attachment 00006_2014-05-26.jpg not found
  • eric77kz
Re: Brakes
31 May 2014 21:12
#634817
I ordered the pads listed on the breakdown provided above and the packaging from Z1 says the ony bike from 77 they fit are 1000 b1 and b2, the only 650s are c2-c4s 78-80!
77 KZ650 C
