Help with clutch cable 83 Shaft KZ750
  • Czun94
  • Czun94's Avatar Topic Author
19 May 2014 17:39
#633013
This is my first motorcycle and I have finally gotten her running but the clutch cable snapped on me. I got a new one but when installed it felt like it was too long because the clutch handle had to pressure on it. I checked everything and no matter what adjustment I did it never felt like it had enough pressure. I checked the size of the new cable and it is the same as the old. Am I missing anything, any steps to set up the cable properly? Any help would be appreciated. Here are some pictures to help you guys find my mistakes, thanks.
  • Czun94
Re: Help with clutch cable 83 Shaft KZ750
19 May 2014 17:41
#633015
It won't let me upload my pictures, any tips on what to check? I am missing the clutch return spring, would that make a difference? I did not have one when I opened the side cover.
  • martin_csr
  • martin_csr's Avatar
20 May 2014 06:40
#633062
The missing spring is most likely the problem.
I'm not familiar w the 750-Shaft clutch cable stuff --- I think it's different from most other KZs.
If you don't have a repair manual, get a Kawasaki factory service manual:
search eebbaayy for KZ750 shaft manual & make sure your bike is included on the model application chart on the back cover.
