1976 kz 900 a-4 Brakes
- Handcannon
76 Kz900 A-4 Brakes
13 May 2014 14:26
Anyone know if the master cylinder for the twin front disk brakes that came on the LTD is different than the one for a single disk. I am finally getting around to adding the second disk for my kz900.
- 4TheKZ1000
Re: 76 Kz900 A-4 Brakes
13 May 2014 14:31 - 13 May 2014 14:58
YES
the dual master cylinder will have 5/8 on it. The bore is bigger to push more fluid.
the single brake master cylinder will have 14 on it.
these are the triangle shaped ones.
YOU CAN SEE THE 14 ON THE SINGLE MASTER CYLINDER
HERE IS YOUR DUAL 5/8 MASTER CYLINDER
Attachment mastercylinder2025800x519-Copy.jpg not found
Attachment 091800x533.jpg not found
Attachment 124800x533.jpg not found
Last edit: 13 May 2014 14:58 by 4TheKZ1000.
- Handcannon
Re: 1976 kz 900 a-4 Brakes
13 May 2014 19:03
Anyone know if the master cylinder for the twin front disk brakes that came on the LTD is different than the one for a single disk. I am finally getting around to adding the second disk for my kz900. I put this in the wrong place and moved it to here.
- Tomolu5
13 May 2014 20:17
The answer you got in the engine catagory was sound. You will need a 5/8" master to push duals. I have one that's in need of a rebuild, maybe more (I have to look)(its ugly as sin) that you could have for the price of shipping+$1.87. Don't quote me, I need to make sure its complete, but its yours if you want it
Mine:
04 Honda rebel 250(wifes)
04 GSXR 750(bolt on galore)
98 CBR 600F3(filter, pipe, adjustable cam sprokets, dyno tune)
76 KZ900A (LTD gauge pods, crash bars, LTD(style)pipes, dyna coils and ignition,headwork and mild port cleanup by cavanaugh racing, K&N filter pods, heck I dunno.
14 May 2014 04:46
Regardless of the category where the question is asked, the answer is still the same. Take a look above at the reply from 4TheKZ1000; he is absolutely correct. Ed
