Wheel swap questions. 80 750.
- Ficarra
05 May 2014 15:10
Hi guys. Just joined because I have no idea where to look to find specs on these bikes. My specific question is dealing with wheels. I have a 1980 Kz750 4 cylinder. It has the mag wheels, and I want to swap on the spoke wheels. Most of the wheels I find on ebay or wherever state that they're for 76-79 or something. What's the difference? What do I need to do or get to make them fit. I'm no stranger to fab work. In fact the bike in question is a far cry from stock. The wheels just have me stumped. I can't seem to find any new wheels on the Web that fit the bike either.
So if anyone could point me in the right direction, it would be much appreciated.
- Twist1
Re: Wheel swap questions. 80 750.
11 May 2014 22:20
Hello Ficarra-I know the front wheel from a 82 750 CSR will fit-the rear wheel from the CSR is a drum brake-maybe you could go with a 750 B model rear, it is a disc but its a 18 inch- maybe you could lace a 16 inch rim to the 18 inch hub. hope this helped,good luck!
Bikes I own,76 KZ 750 Twin-79KZ750 Twin (6700 actual miles)-83 KZ 750 K1 belt drive chopper
12 May 2014 05:21
What 750-4 do you have? Ltd or Standard?
The closest match is probably the 81-82 KZ1000-M CSR. Those models have 48-spoke aluminum wheels, dual disk Fr Br & Rr disk Br. The 1000-CSR has leading axle forks & the same Fr axle as the 750H-Ltd. Until getting a definitive answer, you could do some parts comparisons at Kawasaki.com to see how close everything is.
Note: the 750-CSR Twin wheels are different from the 1000-CSR, but I have no idea if they'd be a good match or not... certainly not the rear, though, since it has a drum brake as mentioned.
