wider rim and tire
- Rocky
kz900 bigger wheel
30 Apr 2014 18:22
hi everyone i switched my rear tire and rim with a bigger one but noticed that when i try to spin the wheel is hard.Is that a sign of bad bearings? i bought it from ebay.the tire is not hitting on anything and my chain is not tight.any ideas?
Re: kz900 bigger wheel
30 Apr 2014 18:27
Sounds like you may have the collars/spaces installed wrong. I would pull the wheel and check the bearings by turning them with my finger. If they feel really smooth, I would mount the wheel again paying very close attention to how the collars/spacers are installed. If they are wrong the wheel will be hard to turn and the bike must not be ridden that way. Ed
- Rocky
- Rocky
03 May 2014 15:40
I checked the collar and the spacer and everything look good.But when i spin the wheel by hand it spins a little and comes to a complete stop and sometimes the chain feels loose or tight when you turn the wheel.my question is was i suppose to change the rear sprocket with a different one? Im using the original one from my smaller rim and tire.
- Rocky
Re: wider rim and tire
03 May 2014 16:06
Hi i put a 4.25x18 aluminum wheel and tire on my 76 kz900 with a 130/80/18 csh1 max tire from a 75 z1900 but my problem is when i spin the wheel by hand it comes to a complete stop right away.sometimes the chain feels loose and tight when you spin the wheel.checked the collar and the spacer and looks good.my question is was i supposed to change the rear sprocket or both sprockets front and back.bearings on the wheel spin fine. need ideas.thanks.
- 4TheKZ1000
03 May 2014 16:33
If the space shown is not installed, when axle is tightened it will bind the bearings and not spin freely.
Attachment kawasaki-kz900-a4-1976-usa-rear-hubbrakechain_bigkar103064710_80fe.gif not found
- Rocky
- steell
03 May 2014 19:36
Get the dimensions from someone that has one, then get a friend with a lathe to make you one.
- StreetfighterKz
03 May 2014 20:04
Also make sure you have #11 as well.
Later, Doug
Later, Doug
1978 z1000 Streetfighter
1976 z900 Stripfighter
1978 Z1R (roller)
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
1978 Z1R (roller)
1979 z650 Resto-Mod
2018 Z900RS
- wireman
03 May 2014 20:05that part is internally installed between the bearings, did you remove a bearing to check for it?Rocky wrote: i dont have that part and nobody sells that part.
- steell
04 May 2014 01:01wireman wrote:that part is internally installed between the bearings, did you remove a bearing to check for it?Rocky wrote: i dont have that part and nobody sells that part.
It's a lot easier to just stick your finger through the center of the bearing and feel for it.
04 May 2014 03:16 - 04 May 2014 03:19Rocky wrote: Hi i put a 4.25x18 aluminum wheel and tire on my 76 kz900 with a 130/80/18 csh1 max tire from a 75 z1900 but my problem is when i spin the wheel by hand it comes to a complete stop right away.sometimes the chain feels loose and tight when you spin the wheel.checked the collar and the spacer and looks good.my question is was i supposed to change the rear sprocket or both sprockets front and back.bearings on the wheel spin fine. need ideas.thanks.
Are sprockets aligned?
Is chain kinked?
Is chain properly lubed?
With chain removed, does the problem persist?
Last edit: 04 May 2014 03:19 by Patton.
