bleeding brakes
  • wikreigs
  • wikreigs's Avatar Topic Author
bleeding brakes
30 Apr 2014 17:18
#630955
I took off and cleaned the front master cylinder from my 83 650. re-assembled put new fluid in. I cannot get the lever to pump up using the manual method . I think the parts are all good. Why can't I get any lever pressure? Do I need a vacuum bleeder?
Re: bleeding brakes
30 Apr 2014 18:23
#630964
If you want to give it a try, here's a homemade vacuum bleeder. Ed
www.kzrider.com/forum/21-tools/318093-bu...brake-bleeder#318093
  • JimB
  • JimB's Avatar
Re: bleeding brakes
30 Apr 2014 19:40
#630974
I had a similar problem. I had luck getting pressure in stages. Start off with no line attached and just use you finger to to cover the hole at the mc. Pump it and you should feel pressure and air escaping. Your finger will not let air in but will let air out. Once fluid is pushing out at that opening then add the first brake line and repeat. Once fluid is coming out of the opening at the end of the line then connect it to the brake and pump again while holding you finger on the bleeder. It takes a while but you have to work the fluid thru. If you do not feel any pressure at the mc hole then you have another issue. Most likely the relief hole in the mc is not able to relief pressure so you will have to adjust your lever to allow the pressure piston to come out past the relief hole, if that makes sense.
1978 KZ1000A2, 1980 KZ1000E, 1980 KZ1000B4 LTD
  • ThatGPzGuy
  • ThatGPzGuy's Avatar
Re: bleeding brakes
03 May 2014 07:31
#631192
Did you bench bleed the MC first? I usually work the lever while watching the relief hole for bubbles. You have to gently move the lever in and out to coax the bubbles out. Unless you do that first bleeding at the caliper is almost a waste of time. You don't have to remove the MC just work the lever while the MC is attached.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
  • Nessism
  • Nessism's Avatar
  • Away
Re: bleeding brakes
04 May 2014 06:21
#631270
In other words, you need to prime the master to get the thing pumping. You can do this with the master installed using a vacuum pump, or even by drawing a vacuum on one of the caliper bleeder nipples with a piece of hose using your mouth. Be careful of the later technique for obvious reasons though.
  • wikreigs
Re: bleeding brakes
05 May 2014 16:19
#631441
Thanks jimB I got pressure in stages like you said. Worked great! Now on to the Carbs.
  • JimB
  • JimB's Avatar
Re: bleeding brakes
05 May 2014 18:07
#631460
Glad it worked for you. Brakes are easy compared to getting carbs tuned properly
  • gengomerpyle
  • gengomerpyle's Avatar
Re: bleeding brakes
06 May 2014 14:20
#631554
vacuum bleeders work great, and do the job quick.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
