Shaft drive (final drive) fluid needed ???
- Spectre 1100
27 Apr 2014 09:21
What oil/fluid should be used on a 1100 Spectre ? I want to go with AMSOIL synthetic, but searched several sights (in vain) with no, or mixed results. Last I seen was 80W-90, but needing to be hypoid ? and what GL classification is required ?
I would prefer a Kaw technician, or former technician response, or someone REALLY into the shaft driven bikes, as the wrong oil will tear it up internally (over time).
1982 Kz1100-D1 Spectre
1965 Corvair CORSA (Yenko Specs)
1971 VW Westfalia
1989 Daytona Shelby
1989 Shelby Dakota
1971 VW Westfalia
1989 Daytona Shelby
1989 Shelby Dakota
- Nebr_Rex
Re: Shaft drive (final drive) fluid needed ???
27 Apr 2014 09:40
You can use the same gear oil as an automotive application.
Just remember synthetic oil.s seem to find any leeks more readily.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- bassie10
27 Apr 2014 10:16 - 27 Apr 2014 10:42
the original manuals of all 3 my kawasaki shaftbikes,GT750, KZ1000ST and KZ1300, mention the same oil for the final gear case oil
API GL-5 Hypoid gear oil.
sae 90 above 5 celsius
sae 80 below 5 celsius
it should not be so difficult to get, over here the local bikeshop sells it..
Last edit: 27 Apr 2014 10:42 by bassie10.
- Hoyt Clagwell
30 Apr 2014 18:35bassie10 wrote: the original manuals of all 3 my kawasaki shaftbikes,GT750, KZ1000ST and KZ1300, mention the same oil for the final gear case oil
What he said. My '84 ZN1100 LTD Shaft uses the same thing. I get the oil from the local automotive parts store. I change mine every two years even though it still looks clean. 80,000 known miles on the bike and still running great with no leaks from the shaft drive unit.
