Converting to Dual Disk Brakes 1977 KZ1000
- chconger
11 Apr 2014 19:57
Hi Guys
Just went out for my first ride on a KZ 1000 in 20 years...Was actually my first ride on a bike in 20 years.
Exhilarating!
Anyhoo...
This winter I rebuilt my masters and calipers, and put in new stainless lines, passed a safety check by a kawai dealer with no issues..and still, that single front disk wants a hell of a squeese to slow in a hurry. More than I recall from[strike] years[/strike] decades ago. Maybe the new pads need to work in, or perhaps I am a feeble old man now...but I want real good brakes if I am going to do this thing!
To convert to dual; is there anyone that sells a kit, or do I have to piece it together? If the latter, is there a list of stuff to buy?
Thanks
Chris
Exhilarating!
Anyhoo...
Thanks
Chris
1977 KZ 1000-A
- richard_oxon
Re: Converting to Dual Disk Brakes 1977 KZ1000
11 Apr 2014 20:13
theirs always stuff u can buy , but perhaps with the new age of sports bikes, about maybe you could use some different calipers ,and or master off one . anyways welcome im sure you will get more reply's by people who know more then me lol .
** KZ1000 B3 1979 ** 1015cc wiseco pistons 33 smoothbores ported head 410 cams
** KZ1000 A1 1977** 1075 wiseco pistons 438 megacycle cams ported head rs34 flat slides
- bluej58
13 Apr 2014 06:21
It depends on how much time you have, if you want it right away you can find everything you need just make sure the master cylinder fits a 7/8 handle bar and is a 15.8 mm or what is referred to as a 5/8 master cylinder.
(NOT)the 14 mm that your bike came with, you need to push more fluid for the brakes to work properly.
Some have a place to attach a mirror, others do not.
You will need a 4 way splitter with a brake sensor or get a MC that has a sensor built in.
There is a lot of Chinese stuff out there and probably some good Japanese and American MC's but they will cost you
I'm using stock parts and rebuilding everything, the parts are out there and if you have some time you can find good deals.
Good luck,
JD
Good luck,
JD
78 KZ1000 A2A
- chconger
15 Apr 2014 03:35
Thanks Guys
Looks like ill piece this together bit by bit as opportunities come up
Cheers
Chris
Cheers
Chris
1977 KZ 1000-A
- 80B4
15 Apr 2014 07:49
For brakes take a look at this upgrade by Steell, he is on this forum.
kz750twins.com/?p=131
His upgrade is nice because it's all Kawasaki.
1980B4 1000
1978 Z1R
1978 B3 750
1978 Z1R
1978 B3 750
