New master cylinders
- mtkawboy
10 Apr 2014 17:41
Does anyone know a source for a decent master cylinder without getting into the high end Brembo stuff ?
Re: New master cylinders
10 Apr 2014 18:22
EX650 or Ninja 650 masters are 5/8" bore and there is a version with a threaded mirror lug. Readily available and cheap on ebay.
The following user(s) said Thank You: mtkawboy
11 Apr 2014 05:33
usa-motorcycles-inc on eebbaayy sells new aftermarket Br mcs
. I think the 12.5mm & 14mm are for a single disk, and the 16mm is for dual disk. Some of them don't have a mirror orifice.
- mtkawboy
11 Apr 2014 09:05
When you buy brake lines for the Ex 650 master cylinder what do you ask for a far as size and the ends ? Sorry Im just not up on all the nomenclature. Thanks again for the help. Im going from what was an LTD down to a shorter handle bar
11 Apr 2014 18:56mtkawboy wrote: When you buy brake lines for the Ex 650 master cylinder what do you ask for a far as size and the ends ? Sorry Im just not up on all the nomenclature. Thanks again for the help. Im going from what was an LTD down to a shorter handle bar
The line size is standard for all the bikes I've seen. Worst case is get a new banjo bolt if the old one doesn't fit.
11 Apr 2014 23:27 - 11 Apr 2014 23:34
I think all of the Japanese bikes have 10mm banjo fittings & oil bolts.
Z1Ent has Goodridge lines & fittings. CycleBrakes has Galfer (sp) lines w crimped-on fittings. I installed the Goodridge stuff... it was easy. I now need a shorter upper Fr Br line, so it'll be easy & cheaper since I can reuse the fittings. With crimped fittings, you have to replace the whole enchilada.
Z1Enterprises.com - Brake Hose 10mm 35 DEGREE BANJO FITTING
Last edit: 11 Apr 2014 23:34 by martin_csr.
