1978 Z1R 16T 630 Countershaft Sprocket
  • PaintWorkz
  • PaintWorkz's Avatar Topic Author
07 Apr 2014 15:21
#628247
I need to stick with a 630 chain and would like to know what is the biggest front sprocket that fits without the chain hitting a stock cover.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
79 CBX Pro Stock project
82 CBX Nostalgia Pro Stock
68 750 Enfield Brat project
82 750 Nourish Triumph LSR
Lake Havasu City, AZ
  • turboking
  • turboking's Avatar
Re: 1978 Z1R 16T 630 Countershaft Sprocket
07 Apr 2014 15:45 - 07 Apr 2014 15:49
#628251
more like how big you can go before it clips the clutch pusher rod.......biggest 630, 16 tooth as I think a 17 will clip the rod and cover.
2005 Kawasaki mean streak
1979 kz 1000 mk II ATP turbo
1975 Z1 960 cc Mr. Turbo
1976 Kz900 1103 cc ATP turbo
1985 GS 1150E
1983 GS 1100E
1997 Suzuki Bandit 1200S
2001 Kawasaki EX 500 Ninja
Last edit: 07 Apr 2014 15:49 by turboking.
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
07 Apr 2014 15:50
#628252
Hey Ralph
If you remember Ted with the 78 Z1R who we talked about at the Bike show, He ran a 16 tooth front sprocket the whole time he had it turbocharged. Might be tight , but it will work.
Thats also what I ran on my LTD With a stock 33 tooth rear
  • PaintWorkz
07 Apr 2014 17:04
#628257
Thanks guys, I will go ahead and order up a 16-32 set up for Bonneville.
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
  • zed1015
  • zed1015's Avatar
08 Apr 2014 01:49 - 08 Apr 2014 01:52
#628295
17 tooth is the largest you can go and although close the chain does not hit the push rod .
I have run a 17t on my Z1R for over 20 yrs with no issues.
Last edit: 08 Apr 2014 01:52 by zed1015.
  • PaintWorkz
08 Apr 2014 04:06
#628301
Thanks for the info Zed, I will do some calculations before ordering sprockets since this gives me more options. I ordered a shorter rear tire to increase the front rake a little to improve high speed handling so I need to gear it taller. I still need to figure out the rpm it will pull at 6psi boost with good valve springs. Traction on the salt throws accurate calculations out the window!
www.paintworkz.com
84 Gpz900 street
77 1135 KZ900 A5
