Mk II shock mounts
  • greenman43
  • greenman43's Avatar Topic Author
Mk II shock mounts
07 Apr 2014 02:28
#628153
Question please guys:
I’m looking to remove the shock mounting studs from my Mk II frame: are they threaded into the frame, or a press-fit ? I’ve tried using a couple of nuts locked together, but there’s no way they’ll unwind. Ditto for using vice-grips on the shank. I suspect I may need to have a lot of heat applied, but just wanted to see how they’re fitted.
Thanks,
Brian
1980 Z1000 A4 Mk II
2007 ZX10R 'SL' (superlight)
1989 GPz900R
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
Re: Mk II shock mounts
07 Apr 2014 02:46
#628155
On the 80 A-4, it show the shock bolt threading into the shock mount.
www.cmsnl.com/kawasaki-1980-kz1000-a4-kz...t/66378.html#results
  • greenman43
07 Apr 2014 04:01
#628158
Thanks, but it's actually the upper mount i'm talking about - the diagram shows the lower mount, where the shock attaches to the swingarm.
It did give me an idea, though, to check the parts diagram on buykawasaki.com: no separate part shown for the stud.
Cheers,
Brian
1980 Z1000 A4 Mk II
1989 GPz900R
  • zed1015
  • zed1015's Avatar
07 Apr 2014 04:40 - 07 Apr 2014 04:40
#628160
The top mount is welded to the frame and the threaded portion is part of the mount.
It is not a stud so will not unscrew.
Last edit: 07 Apr 2014 04:40 by zed1015.
The following user(s) said Thank You: greenman43
  • Mcdroid
  • Mcdroid's Avatar
  • Gone Kwackers
07 Apr 2014 09:29
#628183
zed1015 wrote: The top mount is welded to the frame and the threaded portion is part of the mount.
+1
Those that remove them cut them off.
Michael
Victoria, Texas
1982 GPz750
1977 KZ1000A
1978 KZ1000A
1982 GPz1100
1975 Z2A
  • floivanus
  • floivanus's Avatar
07 Apr 2014 10:13
#628187
The mkII kzs are worth a bit of coin though may want to consider not doing permanant irreversable mods to it
Past; 78 kz1000, 83 kz550
Andrew
  • greenman43
09 Apr 2014 01:33
#628381
Thanks guys, looks like I'll be cutting them off. The difference between my Mk II and a steaming pile of crap is mostly the steam, so no problem making irreversible mods - there's no real value there to preserve.
Cheers,
Brian
1980 Z1000 A4 Mk II
1989 GPz900R
09 Apr 2014 05:42
#628390
The value of the remaining MKII bikes just went up a notch. Ed
  • greenman43
09 Apr 2014 07:37
#628400
650ed wrote: The value of the remaining MKII bikes just went up a notch. Ed
LOL, given the condition of my bike when I got it, they went up that notch quite a while ago !
1980 Z1000 A4 Mk II
1989 GPz900R
09 Apr 2014 10:14
#628423
:laugh: :laugh: :laugh: I understand. :) Ed
