New front end
  • wagonmaster69
  • wagonmaster69's Avatar Topic Author
  • 78 KZ1000A2 / 82 KZ1100 Spectre
New front end
04 Jul 2006 15:43
#59335
I am planning to put a 82 KZ1100 front end on my 78 KZ1000 any suggesions on any bearings I should use?
Its going on this bike..
  • Pterosaur
  • Pterosaur's Avatar
Re: New front end
04 Jul 2006 15:52
#59337
Could'a swore I seen that one in Mad Max... :woohoo:
If you have a choice, go for tapered roller over ball-type bearings. Last longer, distribute load better, feel smoother. Also, come up with some type of weather-seal for the open end of the lower bearing face. I used a trimmed rubber diaphram that fit over the end of the bearing cap between the neck and the triple tree. Keeps all of the road gunk out and lube grease in....
  • Nevco48
  • Nevco48's Avatar
Re: New front end
04 Jul 2006 18:48
#59379
A new front end, and she should be go to go, eh?:)
Where did you find it?
  • bob_z1
  • bob_z1's Avatar
Re: New front end
04 Jul 2006 19:23
#59383
keep in mind that the KZ1100 has a leading axle and will change the way the bike handles.
  • btchalice
  • btchalice's Avatar
Re: New front end
04 Jul 2006 20:35
#59392
my 82 had air ride forks . theyre a pain and i think theyre a few inches longer than the 900/1000
Terry Meyer / Wichita KS
76 kz900 w/1000 motor TWZTD
  • donthekawguy
  • donthekawguy's Avatar
Re: New front end
04 Jul 2006 20:57
#59399
Why not go with a upside down fork set up? Alot cooler and better handling.
Rathdrum Idaho
1971 Kawasaki g3ss
1972 Yamaha R5 350
1965 Suzuki Hillbilly
1964 Yamaha 125
  • wagonmaster69
Re: New front end
04 Jul 2006 22:55
#59416
1 what do you mean upside down forks and 2 will I be better off with the stock forks other than the 1100 air forks ? and this is the front end I was going to use.
  • wagonmaster69
Re: New front end
04 Jul 2006 22:57
#59418
I was wandering can I use the duel disk set up from the 1100 on the 1000 ?
  • btchalice
Re: New front end
04 Jul 2006 23:20
#59419
thats the same spectre front end i have in the garage. if you use the trees and all youll already have the duals. im not sure if the bolt spacing for the caliper mount will fit but i can measure it in the morning. if the seals are good in the forks and they dont leak air then try them.i dont know if you can slide the forks up to get the ride right with the crossover air line though
  • btchalice
Re: New front end
04 Jul 2006 23:23
#59420
these are what upside down forks look like theyre on most of the sport bikes and sell on ebay all the time for less than 500
www.bikernet.com/products/viewsingle.asp?ID=84
Post edited by: btchalice, at: 2006/07/05 02:24
  • wagonmaster69
Re: New front end
05 Jul 2006 18:23
#59566
How much difrents dose it make from a single to a duel disk setup the other front end I have is a mag rim and I like the spoke look better or can I put duel disk on a
the rim I have or will I have to get a difrent front end anywhay if I want a duel setup.
  • btchalice
Re: New front end
05 Jul 2006 19:27
#59574
you can put duals on the spokes if you remove the cover on the non brake side of the wheel you will find the disk mounting holes
