140 on rear?
- kzz1king
140 on rear?
03 Apr 2014 19:23
Looking at new tires,Shinko 777's. 16 inch cast, from a 77 LTD 1000. Have always used a 130 on my wire wheels. Can I go 140 on this wheel? Thanks
Wayne
Wayne
Home built KZ1000 turbo setup
- kaw-a-holic
Re: 140 on rear?
03 Apr 2014 19:28 - 03 Apr 2014 20:44
I'm not a tire specialist but I believe the the 140 will cause a dis-formed tire shape and will not be beneficial to you.
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
Last edit: 03 Apr 2014 20:44 by kaw-a-holic. Reason: content correction
Re: 140 on rear?
03 Apr 2014 20:01 - 03 Apr 2014 20:01kaw-a-holic wrote: I'm not a tire specialist but I believe the the 130 will cause a dis-formed tire shape and will not be beneficial to you.
While this is certainly true for the normal 18 inch rear wheels the LTD has 16 inch wheels that are a little wider. They came stock with 510-18 MT90 size tires. These are equivalent to 130/90 tires. Having said that, I wouldn't put 140 size tires on it for the reason kaw-a-holic mentioned. Putting too wide a tire on a narrow rim will deform the tire's profile which in general negates any benefit of the wider tire. Below is the diagram from Kawasaki.com showing the 1977 KZ1000-B1 (LTD) rear tire size, and below that is a tire chart that shows the metric/inch comparisons. Ed
Attachment 00007_2014-04-03.jpg not found
Attachment 00008_2014-04-03.jpg not found
Last edit: 03 Apr 2014 20:01 by 650ed.
Re: 140 on rear?
03 Apr 2014 22:08 - 04 Apr 2014 05:13
You should have at least a 2.75" wide wheel if you want to run a 140, and preferably a 3.00. You might want to look at the wheel, the size is typically cast into one of the spokes.
Last edit: 04 Apr 2014 05:13 by Nessism.
- racer54
Re: 140 on rear?
03 Apr 2014 23:40
I ca't get the table to load here but it says that a 140 tire should have a 2.75...3.00...3.50 rim. I always thought those 16" rims were 3.00 wide but best to look to be sure which would be in the range suggested for a 140 tire.
- Nebr_Rex
Re: 140 on rear?
04 Apr 2014 03:21
650 and up - 3.00 x 16
440 and down 2.15 x 16
550 ?
550 ?
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- kzz1king
Re: 140 on rear?
04 Apr 2014 14:44
Thanks for the info. Cannot find any marks on rim other than Kawasaki. Outside of bead area is 3.75 inches. I am concerned with chain clearance though. Current tire is a MT90 which is equal to 130/90 i believe. With that tire I have 1/4 to 5/16" clearance. Stock size chain. I suppose I could gain a little by going to the smaller chain.
Wayne
Wayne
Re: 140 on rear?
04 Apr 2014 15:31
Unfortunately, you won't gain clearance by going to a smaller chain. The plane of the inboard face of the sprockets will remain the same, so the inboard link plates will be the same distance from the tire. Ed
- gengomerpyle
Re: 140 on rear?
04 Apr 2014 16:51
i run a 140 on my 750R1
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
1971 Honda CB750K
- kzz1king
Re: 140 on rear?
04 Apr 2014 17:17Thank you sir,had not thought of that.650ed wrote: Unfortunately, you won't gain clearance by going to a smaller chain. The plane of the inboard face of the sprockets will remain the same, so the inboard link plates will be the same distance from the tire. Ed
Wayne
