source for 530 sprockets & chain for 76 ltd 900 ?
  • pete greek1
  • pete greek1's Avatar Topic Author
01 Apr 2014 14:13
#627448
Z1 Enterprise cant get me sprockets, so I can convert,... unique to this year..... Pete
  • slayer61
  • slayer61's Avatar
  • KZR FLAG RELAY CARRIER #62
Re: source for 530 sprockets & chain for 76 ltd 900 ?
01 Apr 2014 14:29
#627451
I've had good luck with Sprocket Specialists.
They even do custom stuff. "reasonable" price and fairly quick service.
The following user(s) said Thank You: pete greek1
  • zed1015
  • zed1015's Avatar
01 Apr 2014 14:30
#627452
The front sprocket uses a Z13 spline pattern and lots of modern kawasakis and suzukis use this with 530 pitch teeth.
If the rear sprocket is 6 bolt then Kawasaki kept the same mount for most of their larger models, so the ZXR750, ZX9R, ZX12 etc 530 rear sprockets will bolt straight on.
Ideally you need a JT or Talon etc sprocket catalogue or friendly bike shop assistant so you can find the ones that fit with the correct tooth count.
  • OnkelB
  • OnkelB's Avatar
01 Apr 2014 14:56 - 01 Apr 2014 15:08
#627454
JT has their catalogue online here: CLICK.
Just select 'Kawasaki' in the 'manufacturer' field and click 'Find bikes' and a list will appear, then as Zed1015 says you need to find the correct spline type (Z13) and a size that works - unfortunately you can't filter the search by spline type so it'll take a bit of browsing.
Did a quick search and it seems a JTF519 (for a ZXR750 H2) will work for your front - it's 530 and available in 17T which is very similar in diameter to your present 15T 630. To maintain your current final drive ratio (2.33) you'll then need a 39T or 40T 530 rear sprocket, obviously with the appropriate bolt pattern and center hole size.
77 KZ 650 B1, 82 GPz 1100 B2.
Last edit: 01 Apr 2014 15:08 by OnkelB.
  • pete greek1
02 Apr 2014 10:49
#627528
Update,.... called JT sprockets & they could only hook me up with a front sprocket , said they don't make one for the rear so then I called Sprocket Specialists, very friendly , told me I would need A 17/42 tooth in 530 which would be the same as A 15/35 tooth in 630 ..... Ordered & on the way ...THANKS Again Guys ...Pete
