Anyone here using the americanclassix rear spacer?
  • jfman
  • jfman's Avatar Topic Author
29 Mar 2014 21:27
#627054
Hello all!
I don have a KZ1000 but apparently my bike (Versys 1000) runs the same bolt pattern (6x104mm with 80mm center ring) for the rear sprocket as the KZ1000 (no certain of this)
Because I am swapping in a wheel from a Versys 650 that has a core that is 11mm narrower than mine I need to shim my rear sprocket out by 11mm and my searching has brought me to this site.
Anyone running this spacer? Are the specs on it really 80mm with a 6x104 bolt pattern? The lip on it is also 80mm?
Anyone knows if that company makes them in other thickness if asked of you have to buy it at 15 mm and get it machined down?
Thank you
Jean
  • Old Man Rock
  • Old Man Rock's Avatar
Re: Anyone here using the americanclassix rear spacer?
30 Mar 2014 06:09 - 30 Mar 2014 06:11
#627074
Can't say for the spacer but if it was machined from the same origin as the counter sprockets, top notch work, German machining quality at it's best.... Machined one piece, not 2 piece welded (teeth to shaft)...
I've ordered several items from them, yes a tad more expensive then other sources but every item I received to date has been on the money regarding quality...
Maybe others will chime in with different history with them....
1976 KZ900-A4
MTC 1075cc.
Head: P&P via Larry Cavanaugh
ZX636 suspension
MIKUNI, RS-34'S...
Kerker 4-1, 1.5" comp baffle.
Dyna-S E.I.
Earls 10 row Oil Cooler
Phoenix, Az
Last edit: 30 Mar 2014 06:11 by Old Man Rock.
