foot pegs with 3" offset
  • tomsbadkz
  • tomsbadkz's Avatar Topic Author
27 Mar 2014 13:14
#626780
hi guys. was wondering if you can still use factory foot pegs with a 3" offset sprocket. I know that it requires the offset support, just didn't know if the foot peg brackets could still be used.
1977 kz1327
Cavanaugh Head 38.6/33
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • StreetfighterKz
  • StreetfighterKz's Avatar
  • Away
Re: foot pegs with 3" offset
27 Mar 2014 15:42 - 27 Mar 2014 15:43
#626812
3" sprocket?! You're either building a dragbike or going for a show queen. :P
Normally when that big of an offset is used, the chain's outside the frame rail and its a drag conversion chassis so stock pegs aren't used.
Later, Doug
1978 z1000 Streetfighter
1976 z900 ‘Stripfighter
1978 z1000 w/RC Turbo
1979 z650 Resto-Mod
1983 Gpz750 Resto-Mod
2018 Z900RS
Last edit: 27 Mar 2014 15:43 by StreetfighterKz.
  • tomsbadkz
27 Mar 2014 17:53
#626827
ok. so I guess ill have to use jackshaft swingarm and sprockets. I kind of figured that. thanks
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
  • Street Fighter LTD
  • Street Fighter LTD's Avatar
  • Moderator
  • Moderator
27 Mar 2014 18:27
#626835
3 inch offset/ jack shaft ? Are you running a 8 inch slick ?
With something that extreme you usually would have rearset controls and rely on a air shifter
  • tomsbadkz
28 Mar 2014 01:35
#626861
setting up for a 300 tire. thought it would be a cool look for an old school KZ.
1977 kz1327
38mm Flatslides
MRE racecut trans
300mm rear tire
Web Cams 435/465
