whats the best chain ?
- pete greek1
21 Mar 2014 14:38 - 21 Mar 2014 14:38
630 - roller, o ring, or x ring ??
Last edit: 21 Mar 2014 14:38 by pete greek1.
- slayer61
- KZR FLAG RELAY CARRIER #62
Re: whats the best chain ?
21 Mar 2014 15:25
630 is passed it's prime. A 530 is perfectly suitable for any modern bike. No ring = less drag but more maintenance. O ring = most drag minimal maintenance. X ring = less drag than O ring and similar maintenance.
The following user(s) said Thank You: pete greek1
- bountyhunter
21 Mar 2014 16:46
Z1 sold me a really good X ring chain at the lowest price on the net I could find.
- koolaid_kid
21 Mar 2014 20:23
Do yourself a favor and convert to a 530 setup. There are a lot more choices in chains. And they weigh less and are stronger than the original 630 chain.
While o-ring chains are good, the best are x-ring chains. Again, lots of choices in x-ring chains once you convert.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- ThatGPzGuy
22 Mar 2014 05:54Z1 hooked me up with a 530 x-ring chain with the correct size sprockets. It was long overdue...bountyhunter wrote: Z1 sold me a really good X ring chain at the lowest price on the net I could find.
Make sure you get enough length because it will be different (depending on the sprocket sizes) and be mindful you may be limited on the size of the front sprocket.
Jim
North GA
2016 Yamaha FJR1300ES
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
1979 Yamaha XS650 cafe'
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
North GA
1982 GPz750 R1
1974 Kawasaki H1
1976 Kawasaki KZ400
2001 KZ1000P (sold)
2001 Yamaha YZ426
1965 Mustang
1967 Triumph GT6
1976 Bronco
22 Mar 2014 08:34
I've been using a D.I.D. 530 O-ring chain for more than 20,000 miles and it has barely stetched or worn at all. At the rate it is going I have no doubt it will last 50,000 miles or more. Im told their X-ring chain may be even better. I use Maxim Chain Wax about every 300 or so miles. Ed
- wakeboardr42393
22 Mar 2014 15:27
what about the OEM chain? what's the consensus on that? I assume it'd be a quality item.
1981 Kawasaki KZ 550 LTD
1987 BMW 325is
1987 BMW 325is
22 Mar 2014 15:45 - 22 Mar 2014 15:45
The genuine Kawasaki chain is a high quality item. They can be fairly expensive unless you find a good deal on a NOS (new old stock) one on eBay. My KZ650-C1 originally came with an endless O-ring chain that I believe was made by EK. One thing to keep in mind, if your chain is endless you must remove the swing arm to install it. DON'T cut it. Ed
Last edit: 22 Mar 2014 15:45 by 650ed.
- dejavoodo41
22 Mar 2014 16:47 - 22 Mar 2014 16:50
I'm running the RK GB530GXW. It has 10K / lb. tensile strength and a wear index of 1000. It's for street bikes up to 1400 cc and is their replacement chain for the Hayabusa. I keep it clean and lubed and it's working great for me.Swapping to a 530 setup is definitely worth it. It saved a bunch of weight and seemed to make the bike run a bit smoother.
1977 KZ1000A With 1980 KZ1000A MKII engine, Wiseco 1105 kit, Dyna S Ignition, 3 Ohm Dyna Coils, Cams, Mikuni RS34 Carbs, Vance and Hines Pro Pipe with Comp Baffle
New Smyrna Beach, FL
Last edit: 22 Mar 2014 16:50 by dejavoodo41.
- bountyhunter
22 Mar 2014 18:22Mine wore out pretty quickly but I probably did not lube it enough. A modern X ring chain is much better IMHO.wakeboardr42393 wrote: what about the OEM chain? what's the consensus on that? I assume it'd be a quality item.
- pete greek1
23 Mar 2014 11:28
Well, Thanks for all the input, I was going to get new sprockets also, so I might as well switch to the 530 set up & get with the times, just because I'm a dinosaur, doesn't mean my bike has to be !!!
