caliper rebuild
  • gengomerpyle
  • gengomerpyle's Avatar Topic Author
caliper rebuild
20 Mar 2014 16:45
#625938
what is the secret to getting the dust cover in the groove?
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
  • Nessism
  • Nessism's Avatar
Re: caliper rebuild
22 Mar 2014 06:03
#626128
Install the dust boot over the piston, positioning it at the very bottom of the piston (opposite side of the groove in the piston), then install the boot into the caliper groove before pushing the piston down into the bore. Some brake fluid on the piston will help it slide easier during install.
The following user(s) said Thank You: gengomerpyle
  • gengomerpyle
Re: caliper rebuild
22 Mar 2014 06:06
#626129
thanks, i will give it a shot
1982 GPZ750R1 ELR
1971 Honda CB750K
  • gengomerpyle
Re: caliper rebuild
31 Mar 2014 11:15
#627220
thanks for the advice, it worked like a charm. had them together in less than 5 minutes each
Nessism wrote: Install the dust boot over the piston, positioning it at the very bottom of the piston (opposite side of the groove in the piston), then install the boot into the caliper groove before pushing the piston down into the bore. Some brake fluid on the piston will help it slide easier during install.
1982 GPZ750R1 ELR
1971 Honda CB750K
