Kz550 tire change
  • nickleo373
  • nickleo373's Avatar Topic Author
Kz550 tire change
14 Mar 2014 21:07
#625222
Hey everyone
My 550 just failed inspection because the tires are almost bald. I went to the dealer and ordered two new tires. They charge a ton of money to take the wheels off the bike and change the tires so I want to take them off myself and only bring the wheels into the dealer. I don't have any stands to support the bike other than its center stand. I'm pretty sure the center stand is enough to take the rear wheel off but does anyone know of a way to support the front of the bike so I can take the front wheel off?
1981 KZ550C LTD
"If you ain't first, you're last"
  • Boudewijn
  • Boudewijn's Avatar
  • I like to tinker
Re: Kz550 tire change
15 Mar 2014 05:24
#625242
Grab some bricks and some pieces of wood. Just gently lift the front and put the bricks somewhere under the bike for support. Place wood between the bricks and the bike so you dont damage the paint.
1983 KZ200
1993 Jawa 640
1989 Honda CB-1
Opinions are like assholes. Everybody's got one and everyone thinks everyone else's stinks. :-)
15 Mar 2014 05:38 - 15 Mar 2014 05:40
#625245
I always change my own tires, so I do them one at a time. If you want them both off at the same time you can remove the rear tire first then (with the bike still on the center stand) use a little bottle jack under the front of the engine to lift the front wheel off the ground. Use a small block of wood between the jack and oil pan to protect the pan. Ed
Attachment 00007_2014-03-15.jpg not found
Last edit: 15 Mar 2014 05:40 by 650ed.
  • lightitup
  • lightitup's Avatar
15 Mar 2014 11:50
#625285
i just use a jack stand to keep the front up when the front tire is off
81 kz 550 ltd
  • bountyhunter
  • bountyhunter's Avatar
15 Mar 2014 12:54 - 15 Mar 2014 12:56
#625301
nickleo373 wrote: Hey everyone
I think you can use a hyd jack with a piece of wood under the edge portion of the oil pan (not the center) but it's a risk to use that. 650Ed showed the best way, keep the lift point near the edge of the pan because it's a lot stronger than the center.
Last edit: 15 Mar 2014 12:56 by bountyhunter.
  • gengomerpyle
  • gengomerpyle's Avatar
15 Mar 2014 14:36
#625309
put it on center stand and put some weight on the back of the seat. it should raise the front tire off the ground. but you cant do both tires at the same time.
1982 GPZ750R1 ELR
1978 Honda CB750F SuperSport
1971 Honda CB750K
1970 Honda CL100 Scrambler
