Brake pads for '83 KZ750E
- karoliens
27 Feb 2014 01:55
No eBay APP ID and/or Cert ID defined in Kunena configurationHi all,
Are '83 Kawasaki KZ750E front and rear brake pads same? Because I removed old ones and front/rear brake pads has same form except one pad was thicker. Now I'm after these It is written "front" but the rear ones are in same form.
83' Kawasaki KZ750E-L2
Re: Brake pads for '83 KZ750E
27 Feb 2014 04:31Good Fortune!
27 Feb 2014 05:15
I thought 1982 was the last year Kawasaki made a KZ750-E model. It was the KZ750-E3. On the E3 the rear pads are different than the front even though they may look the same at first glance. Sometimes a different pad thickness (it can be the metal back plate, not just the pad material) is the only difference, but it is different because the pads match the rotor, and the front rotors are a different thickness than the rear rotor. Ed
- koolaid_kid
27 Feb 2014 07:05
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
- karoliens
27 Feb 2014 23:56
On chassis plate it is written: KZ750E037315.
28 Feb 2014 06:45
My guess is that the bike isn't a North American model.
I don't think the E in the chassis number necessarily indicates that it is a 750E.
- JR
28 Feb 2014 07:47 - 28 Feb 2014 07:52
the front and rear brake pads on my 1980 750E1 are different.
According to Z1 Enterprises the front and rear brake pads are different part numbers and fit all the following KZ750E1-E3/H1-H4/R1/N1/N2/F1/L3
I dont know what the difference is. Could be thickness. I just buy the correct part number and install. No point messing with brakes
Last edit: 28 Feb 2014 07:52 by JR.
- koolaid_kid
28 Feb 2014 12:39
If you could post a few pictures it might help us identify the bike for you.
1983 GPz 750
28 Feb 2014 13:09Attachment picpostnewsite912x671.jpg not found
- karoliens
01 Mar 2014 02:13Attachment 1497469_3801797139476_213488408_n.jpg not found
- undiablo
01 Mar 2014 02:43
My kz750 H2 uses the same brake pads front and back.
Kawasaki KZ 750/4 LTD 1981
Kawasaki KLR 650 2011
Argentina - Buenos Aires
