GPz1100A1 suspension sleeves
- rsvfletch
26 Feb 2014 12:06
Hi does any one have a set of the hardened sleeves that go into the needle roller bearings on the shock linkage? Mine are shot and i can't find any. I would normally machine another set but as they are case hardened it's out of my league!
Re: GPz1100A1 suspension sleeves
26 Feb 2014 13:38
Take a look at the diagram below. Which pieces do you need? Ed
Attachment 00009_2014-02-26.jpg not found
- rsvfletch
26 Feb 2014 23:48
Hi i need to replace the 3 sleeves that go through the needle roller bearings-
42036
42036A
42036B
I've beed on cmsl and a few other sites but 2 of them are un available.
Typically it's holding up my progress now.
Thanks
42036
42036A
42036B
Thanks
27 Feb 2014 06:17
OK. The sleeve marked 42036 is still an “Active” Kawasaki part, so any dealer can order it for you. Z1Enterprises (Z1E) should be able to get it for you for around $15 or so. The other two sleeves (marked 42036A and 42036B) are no longer available from Kawasaki. I looked through the usual online parts houses but was not able to find anyone with part number 42036-1072 or 42036-1075. You may want to check with Z1E to see if those parts are still available in Japan. A while back Jeff was kind enough to order a part for me that was available in Japan but not in the US. It took a while, but it was well worth the wait. If they cannot get the parts and if no one else has them you may need to take your old parts to a machinist and have him replicate them. Ed
Attachment 00007_2014-02-27.jpg not found
- koolaid_kid
27 Feb 2014 07:08
Back in the late 90's Jeff ordered a cable for my 81 KZ750E that was not available in the states.
Took a while, but cemented my loyalty to Z1.
1983 GPz 750
810 Wiseco, Kerker, K&N, DynoJet S3, Accel, Progressive, etc.
27 Feb 2014 07:27
how about machining out the sleeves and then doing your own heat treating?
(i.e. heat until cherryred and dunk in used engine oil,brine water,your favorite solution of ??????)
- rsvfletch
27 Feb 2014 08:16
That's an option I'm just not sure how hard they'd need to be?
27 Feb 2014 08:44rsvfletch wrote: That's an option I'm just not sure how hard they'd need to be?
soo,
very true.
although it is one i have the capacity to perform.
before i did without for one day i would do just as i said.
let us no how you work it out.
- kzz1king
27 Feb 2014 11:59
No eBay APP ID and/or Cert ID defined in Kunena configurationMaybe this guy? Has sleeves for a lot of GPZ arms, maybe if ID/OD was correect you could cut to length?
Wayne
Wayne
Home built KZ1000 turbo setup
- rsvfletch
27 Feb 2014 12:17
Cheers guys I'm leaning towards making a few out of stainless so that I have spares. It's not my main bike so it won't get hammered too much!!
