KZ650 D2 CSR Alternate seat options
- jesiman
17 Feb 2014 14:08
Hey guys, while my carbs are being rebuilt by George. shout out to
, I am looking to get a seat to re cover. Problem is, there are so many variances with the bike that I just don't know what will and won't fit. I have the part number from partzilla as 53001-1135, and I know the other bikes that that particular seat fits, but I don't know if any other seats will fit that bike. Does the B fit? I read about there being a difference in frames on certain bikes such as the rear being a hoop rather than a box, but again, I just don't know. What seats will bolt on to my frame. Not looking to do anything custom nor universal. Just need the pan to bolt up to the stock frame. Any info would be GREATLY appreciated. Thanks!
Here is what partzilla says the seat for my bike fits.
KZ650-D1 SR SEAT
KZ650-D1A SR SEAT
KZ650-D2 SR SEAT
KZ650-E1 LTD SEAT
1978 KZ650-D1 SR SEAT
1978 KZ650-D1A SR SEAT
1979 KZ650-D2 SR SEAT
1980 KZ650-E1 LTD SEAT
KZ650-D1 SR SEAT
KZ650-D1A SR SEAT
KZ650-D2 SR SEAT
KZ650-E1 LTD SEAT
79 KZ650 SR
84 ZN700 donor
81 KZ440......no title....
84 ZN700 donor
Re: KZ650 D2 CSR Alternate seat options
17 Feb 2014 17:49 - 17 Feb 2014 17:53
You're probably going to have to use a seat from an SR or Ltd, as indicated by the cross-reference.
The B & C seats may bolt to the frame (maybe not?), but they are shaped at the rear to fit around a ducktail which the SR & LTD do not have.
From Kawasaki.com for the 79 D2:
53001-1135 -->> alternate part number (but it may not be very useful) 53001-1007
Model (4):
KZ650-D1 (SR) (1978)
KZ650-D1A (SR) (1978)
KZ650-D2 (SR) (1979)
KZ650-E1 (LTD) (1980)
FYI, the 81-83 650-CSR models are different.
Model (4):
Last edit: 17 Feb 2014 17:53 by martin_csr.
- Nebr_Rex
17 Feb 2014 18:45
Post a pic of the framework below the seat and we can tell you.
The SRs have a tube that loops around from one side to the other.
The B and Cs have tubes that run straight back.
2002 ZRX1200R
81 GPz1100
79 KZ1000st daily ride
79 KZ1000mk2 prodject
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
77 KZ400/440 cafe project
76 KZ400/440 Fuel Injected
81 GPz1100
78 KZ650sr
78 KZ650b
81 KZ750e
80 KZ750ltd
- jesiman
17 Feb 2014 21:02
79 KZ650 SR
84 ZN700 donor
84 ZN700 donor
- jesiman
21 Feb 2014 05:45
First off, thanks Martin for pointing me in the right direction with the correct OEM seat.
Now, I think there may be a problem. It appears as though my frame has been "modified". Looks like the tabs are missing for the seat hinges. The other problem is that I don't weld. Or maybe I'm wrong here. Does this look stock? The pics on partzilla of the frame don't look near the same.
79 KZ650 SR
84 ZN700 donor
84 ZN700 donor
21 Feb 2014 06:10
You're correct; some nitwit with a hacksaw and welder has modified your frame. The diagram below shows the stock configuration. Ed
Attachment 00007_2014-02-21.jpg not found
21 Feb 2014 06:26 - 12 Aug 2014 12:56
No eBay APP ID and/or Cert ID defined in Kunena configurationI don't know that much about the 70s 650s, but it appears the frame has had some stuff cut off of it. I could be wrong, but in addition to the missing seat hinge pin mounts, it looks like some engine mounts & other stuff may have been lopped off as well.
Here's a frame for comparison - from the number on the steering head I believe it's a 78 SR. You probably ought to check your frame & engine numbers to make sure what bike you have. jarlef z650
Last edit: 12 Aug 2014 12:56 by martin_csr.
