Seat issues
- johnjones750csr
Seat issues
16 Feb 2014 07:56
Hello everyone,
I have an 82 750CSR and I'm doing some light restoration to it so it's reliable and looks decent. I ride it everyday and it's an enjoyable bike to ride. I'm slowly replacing all the pieces that are bad and need it.
One big issues is the seat, The cover is shot, and the seat pan under is in pretty bad shape with rust etc. So bad to the point that there really isn't anything to attatch the seat cover to anymore on one side. My question is, does anyone know of any good replacements available or reproductions of this piece? I'd like to get it replaced and get a new seat cover for it.
Thanks
John Jones
82 750 csr
Thanks
John Jones
82 750 csr
Re: Seat issues
16 Feb 2014 09:01
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationThe first eBay listing below says it's a seat cover for the 1982 KZ750-CSR. The second listing below looks like it might be a good seat pan, but I don't know if it fits your model bike. The seller says it's for a KZ750-CSR, but says 1981 and then says 1980, but the on KZ750-CSR I see listed at Kawasaki.com is the 1982 KZ750-M1 (CSR). You may want to inspect the pics carefully and it it looks like the pan is identical to yours you may want to make him an offer. If that's the correct pan and you put the new seat cover on it, it might look good. Ed
Re: Seat issues
16 Feb 2014 10:20 - 17 Feb 2014 06:59
I don't think that is the correct seat. The other 750T stuff the seller has listed appears to be for the 1980 KZ750-G1 Ltd Twin which doesn't have much in common w the 750-CSR, except for the engine. The 750-M1 CSR is pretty much different from the G1 & earlier 750-Twins. The CSR is more similar to the 83-84 750 Ltd Belt twin models & the cross-reference at Kawasaki.com indicates that they have the same seat (82-84 KZ750-M1/K1/K2).
Last edit: 17 Feb 2014 06:59 by martin_csr.
- johnjones750csr
Re: Seat issues
16 Feb 2014 11:36
Yes, I have already scoured ebay for one, I have not found one yet that matched. I'm going to keep looking but I dont see stuff pop up too much for this bike. sucks, because it runs so good. I might have to just take it apart and take it to someone and have them play doctor with it and see if they can't get it back to at least usable condition.
martin_csr wrote: I don't think that is the correct seat. The other stuff the seller has listed as being for the 750T appears to be for the 1980 KZ750-G1 Ltd Twin which doesn't have much in common w the 750-CSR, except for the engine. The 750-M1 CSR is pretty much different from the G1 & earlier 750-Twins. The CSR is more similar to the 83-84 750 Ltd Belt twin models & the cross-reference at Kawasaki.com indicates that they have the same seat (82-84 KZ750-M1/K1/K2).
- bountyhunter
Re: Seat issues
16 Feb 2014 13:33
There are internet bike dismantlers that are pretty reputable and typically more knowledgable that ebay bozos.
If you get a decent pan, a car upholstery shop can put a seat cover on it and even buff up the stuffings. They did a great job on mine.
- johnjones750csr
Re: Seat issues
16 Feb 2014 19:41
That's the next thing I'm going to check, I'm also going to check the local bike junk yard....I hate that place, the people who work there are assholes...but I"ll give them a shot. If all else fails....I might be able to make one out of fiberglass or have the existing one repaired by someone who does metal work. One way or another, it's gotta get fixed.
bountyhunter wrote: There are internet bike dismantlers that are pretty reputable and typically more knowledgable that ebay bozos.
Re: Seat issues
16 Feb 2014 20:00Perhaps the Alligator Strip would be an option.johnjones750csr wrote: ... seat pan under is in pretty bad shape with rust etc. So bad to the point that there really isn't anything to attatch the seat cover to anymore on one side....
www.hvccycle.com/seats.html
