78 KZ 1000 swingarm swap
- Scott441974
15 Feb 2014 18:03
Looking to swap swingarm to accommodate a wider tire. Anyone know which ones will fit without serious mods. Minor welding and such is no problem.
- TerryK
Re: 78 KZ 1000 swingarm swap
15 Feb 2014 20:46
GS1000 Suzuki is a pretty easy swap, but those arms are getting scarce. I used a 87 GSXR arm on mine but it required a good bit of work and welding.
1977 KZ1000
GSXR swingarm and rear brake
WM6 rear Akront rim
Wiseco 1075c pistons
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
Dyan 4000 SP ignition
etc
Ontario, Canada
WM6 rear Akront rim
33 smoothbores
stage 3 Web Cams
Head porting
Dyna S ignition
Lockhart oil cooler
Wiseco header
1980 Z1R drag bike
1200cc
38 Flatslides, .
500' cams
7" slick
etc
Ontario, Canada
- wireman
16 Feb 2014 18:50
Early 80s gs1100 suzuki works, make sure to get shocks with it.
Just takes a little shimming
