kz750 front end swap
  • Schmeck
  • Schmeck's Avatar Topic Author
Re: kz750 front end swap
15 Feb 2014 20:48
#622417
Found it . Measurements for stock front bearing is 6203-2RS = 17 ID 40 OD 12 thickness
Now I just need to switch some numbers around for the right bearing.
1979 kz750 twin -Soon to be roadworthy
1988 El250 engine in custom hard tail frame - collecting dust
  • Schmeck
15 Feb 2014 21:08
#622419
At last. found what I need. 6203-RS3/4
Never would have thought to add the 3/4 to the end . :whistle:
  • Schmeck
15 Feb 2014 21:45
#622421
Okay this confuses me and I need some input. Here is the link to the bearing I will most likely get. I ran the load capacities static and dynamic to pounds and the bearing should work.
It is sealed though?? My bearings that I removed were not sealed in the bearing but actually a separate seal. Do I buy this bearing and then just get the seals separate?
  • Schmeck
15 Feb 2014 21:46
#622422
  • steell
  • steell's Avatar
17 Feb 2014 14:47
#622576
The RS means it's a sealed bearing. You can pop the seals out and use external seals, leave the seals in and use external seals, or leave the seals in and skip the external seals.
  • Schmeck
17 Feb 2014 17:15
#622593
Okay here's an update . I emailed DNA about getting a bigger stem and I don't think it's going to work because the bottom lip on the stem is like 31mm and 30mm is the stock kz750 stem . Too close I think . Also the only bearing races that allballsracing carries that could work are slightly too much width.
The closest on top is a 48x13 which is 1mm more than stock and bottom is 52x16.5 which is .5 more than stock .
Here is what makes me curious and I can post a picture if you want . The bottom bearing race sits further into the fork shaft . The bearing on the springer is flush on the bottom tree there about . The springer tree is going to hit the fork shaft before the bearing seats the race .
Would trimming the bottom of the fork shaft outside closer to the race fix this or is there another solution?
  • Schmeck
17 Feb 2014 17:23
#622594
Nevermind the bottom race. I'm sure it will fit okay lol I think I will probably just have to buy a stock kit and just toss the 30mm Id bearings since I have bearings to fit the springer.
