1980 KZ1000 Drag Bar Install Help
  • ChopFinger123
  • ChopFinger123's Avatar Topic Author
13 Feb 2014 13:53
#622136
Im trying to get a set of drag bars installed on my 1980 KZ1000 Shaft and Im having some trouble. I can get everything on but the front master cylinder is my problem. It is hitting the RPM tach which isn't really a problem (i don't think anyway) but the brake line seems to be too long and i can't get it mounted like it is now.
If anyone has done this mod and has some advice it would be greatly appreciated and if someone hasalready asked this and been answered point me to the answer lol. Thanks in advance for any advice.
  • floivanus
  • floivanus's Avatar
Re: 1980 KZ1000 Drag Bar Install Help
13 Feb 2014 14:06
#622139
Need to get everything mounted up, measure out what length you need and source a new shorter brake hose for your bike
Past; 78 kz1000, 83 kz550
Andrew
  • ChopFinger123
13 Feb 2014 14:44
#622145
Thanks. Id really like to go to stainless braided line anyway. I think this whole front brake set up is FUBAR.
Sent from my SCH-S720C using Tapatalk 2
  • z1kzonly
  • z1kzonly's Avatar
13 Feb 2014 19:47
#622174
Too Bad, day late and 20 dollars to short.
I just sold this yesterday on ebay with a buy it now.
Went down to Florida.
13" line with a 90 degree banjo.
Plus pull your throttle assembly back a little, down the bar about an inch. Give you a little more room.
This is what just sold.
cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&r...7260432#ht_392wt_891
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
13 Feb 2014 19:53
#622175
  • ChopFinger123
15 Feb 2014 15:33
#622375
Does anyone know if i can put a smaller master cylinder on the front?
I think that would fix all the problems.
  • ChopFinger123
16 Feb 2014 12:00
#622465
Or can i put a different throttle control on it? Im wanting to relocate the start button and kill switch anyway.
If anyone can help i would really appreciate it.
  • wireman
  • wireman's Avatar
16 Feb 2014 18:47
#622496
Drag bars come in differant widths, make sure to get the right ones.
  • ChopFinger123
16 Feb 2014 23:10
#622512
I think I've got it figured out. The new grips i bought for the bars are about a 1/2" shorter than factory grips. So i have to cut the throttle control off a little bit and it should all fit about right. I may still have to put a 90* banjo on it but Im gonna replace the lines anyway.
