Bearing race removal
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: Bearing race removal
13 Feb 2014 17:48 - 13 Feb 2014 17:52
#622159
You were fortunate. Mine was a bear to get off. But the most trouble I had was the race on the bottom of the steering neck. I used a long punch and got it from the top. But id didn't want to come out evenly. and left burs on the inner diameter which I had to deal with afterwards. If I had to do it again, I would put a heat gun or torch onto the bottom of the neck to expand it a bit and then tap it out. Didn't do that cause I didn't want to damage the paint on the neck. But in retrospect, I could done a quick respray in that area afterwords. Would have saved me a lot of grief. Hope yours is much easier coming out.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 13 Feb 2014 17:52 by KZJOE900.
  • RonKZ650
  • RonKZ650's Avatar
13 Feb 2014 19:32
#622171
On mine a chisel has always taken it right off, as the stem is tapered and only takes a small amount of movement to pop off the race. Otherwise harbor freight sells their Chinese bearing splitter tool kit for a good price that works fine.
