brake bleeding
- Mark Stark
brake bleeding
09 Feb 2014 18:36
Hey guys! im calling upon your guy's infinite wisdom. I just bled my brakes and am getting a steady flow of brake fluid but there is a problem. in order to successfully brake I have to pump the brake lever a couple times before the lever feels good. it first starts out spongey and eventually gets normal. please I need some advice people. I really appreciate it!
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- murquiza
Re: brake bleeding
09 Feb 2014 18:41
You still have air in the lines. Bleed it again.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- Mark Stark
Re: brake bleeding
09 Feb 2014 18:45
should I completely bleed it again. I hear that air can get trapped in the part where the MC line splits.
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- murquiza
Re: brake bleeding
09 Feb 2014 19:13
Do you have a vacuum pump? I strongly recommend it for bleeding brakes. You can do one side and get a feel of the lever, if it is still soft do the other. I would do both though.
Bikes:
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
1979 KZ650-D2 SR
2006 Vulcan 2000-A
2006 ZX10R
2008 Versys KLE650
- kaw-a-holic
Re: brake bleeding
09 Feb 2014 21:11
I use a pump that I bought from Arbor Freight for less than $20 and it works great
Jon
1977 KZ1000a1
Mesa, AZ
Phoenix Fighter Project
1977 KZ1000a1
Mesa, AZ
Re: brake bleeding
10 Feb 2014 04:43
Take a look at the following link. Notice the advice in "Trade Secrets." Ed
www.helperformance.com/bleeding-instructions.html
- Mark Stark
Re: brake bleeding
10 Feb 2014 06:36
Thank you guys for the help. I think im going to try the over night trick and see if that helps. but I will definently invest in that bleed kit from HB. Thank you again! really appreciate.
1979 Kawasaki KZ650
Stark Industries
Stark Industries
- kzz1king
Re: brake bleeding
10 Feb 2014 09:54
This is always my last step and I will do it several times. It works qite well.
Wayne
Wayne
650ed wrote: Take a look at the following link. Notice the advice in "Trade Secrets." Ed
Home built KZ1000 turbo setup
- Mark Stark
Re: brake bleeding
15 Feb 2014 08:13
thanks guys for all the helpful advice. i did the overnight trick and it worked like a charm!! so once again thanks!!
1979 Kawasaki KZ650
Stark Industries
Stark Industries
