kz650 1981 Mag wheels
  • Bennett
  • Bennett's Avatar Topic Author
08 Feb 2014 18:05 - 08 Feb 2014 18:05
#621579
I found a set of wheels, Yamaha Honda street fighter mag wheels
MT2.50 x 16 Rear mag wheel
19 " Front Mag
Does any one know if they will fit on a 1981 kz 650
Last edit: 08 Feb 2014 18:05 by Bennett.
Re: kz650 1981 Mag wheels
08 Feb 2014 19:24
#621592
You will most likely need different bearings and spacers plus I seriously doubt that the disk rotors will match the calipers, and if it has a drum rear brake I doubt the brake linkage will match. Sounds like an awful lot of work to graft Honda or Yamaha wheels to a KZ. Why not simply get KZ wheels for the KZ? Ed
  • martin_csr
  • martin_csr's Avatar
09 Feb 2014 07:20 - 09 Feb 2014 08:04
#621644
I guess those wheels are kinda modern & fancy looking?
If you decide to do as 650ed suggested, KZ550-Ltd wheels are a direct swap - all you need are the wheels & the Fr Br disk.... everything else swaps. I installed a set from a 1980 model. Other wheels will work.
Not the wheels, but for street fighter mode you could install the cylinder block & pistons from a 750-4.
For a penultimate 650-CSR you could then go with a Wiseco 810 piston kit from Ape Racing . :)
Last edit: 09 Feb 2014 08:04 by martin_csr.
