Shortest rear shock/strut KZ1000 shaft?
Re: Shortest rear shock/strut KZ1000 shaft?
09 Feb 2014 10:41 - 09 Feb 2014 10:42
Assuming your current tire is about 130/90-17, going to an 80 series tire should give about an extra 1/2" between the top of the tire and the fender. This will help. Patton's idea of bouncing on the bike with a ball of clay on the tire is a good idea. If you do that you should be able to see how close the tire comes to the fender which should help you figure out if the 1/2" gained by moving to an 80 profile tire is enough. 1/2" may not sound like much, but it could be the difference between hitting and not hitting. The link below has a tire height calculator about 1/2 way down the page that will let you plug in tire sizes to see the tire's height. Remember to divide the difference in height by 2 to see how much more clearance there is between the tire and fender. Ed
www.rbracing-rsr.com/tirediamcalc.html
Last edit: 09 Feb 2014 10:42 by 650ed.
The following user(s) said Thank You: Serpent7
- Serpent7
- Nothing professionally, only for fun...
13 Feb 2014 17:14650ed wrote: Assuming your current tire is about 130/90-17, going to an 80 series tire should give about an extra 1/2" between the top of the tire and the fender. This will help. Patton's idea of bouncing on the bike with a ball of clay on the tire is a good idea. If you do that you should be able to see how close the tire comes to the fender which should help you figure out if the 1/2" gained by moving to an 80 profile tire is enough. 1/2" may not sound like much, but it could be the difference between hitting and not hitting. The link below has a tire height calculator about 1/2 way down the page that will let you plug in tire sizes to see the tire's height. Remember to divide the difference in height by 2 to see how much more clearance there is between the tire and fender. Ed
Yes! My front tire is a 110/90/19, and rear is a 130/90/17. I need to purchase tires this spring before riding season. I'm thinking of going with 100/80/19 in the front, and 130/80/17 in the rear.
19 Audi Q5
14 Volkswagen Touareg X
97 Honda Shadow Spirit
79 Kawasaki KZ1000 st
79 Volkswagen Transporter
73 Volkswagen Thing
73 Volkswagen Thing
- Serpent7
13 Feb 2014 17:17Patton wrote: Could remove one shock, place a ball of modeling clay on top of the rear tire, set the remaining single shock to minimum spring pre-load, then mount the bike, using forceful aggressive bouncing to compress the rear suspension travel as much as possible.
(The single shock facilitates maximum rear compression, for test purposes.)
After the bouncing exercise, inspect the clay to determine what if any clearance existed between tire and fender at maximum compression.
Even without the clay, the fender may impact the tire, which should be readily noticeable by the bouncing tester. :lol:
That is a great idea to test!
19 Audi Q5
73 Volkswagen Thing
73 Volkswagen Thing
