83 kz750 fork cap removal
  • Troyn
  • Troyn's Avatar Topic Author
08 Feb 2014 10:03
#621538
Replaced the fork seals but I can't figure out how to remove the caps in order to fill with fork oil. On another bike the caps had either a hex head or socket fitting, but the caps on this bike just have perfectly round indentations. I have the manual and it just says to remove the caps to fill. :huh: The diagram makes it look like there's a circlip on top of the cap but I don't see that on mine.
Please help! Thanks.
1983 kz750 ltd shaft, 4-cyl, stock everything :)
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
Re: 83 kz750 fork cap removal
08 Feb 2014 10:52 - 08 Feb 2014 10:55
#621544
Not familiar with your model but here is a link with the parts:
www.cmsnl.com/kawasaki-1983-kz750-f1-ltd...t/19070.html#results
Looks like it has a circlip that holds the top plug in place. Looks like a similar system used on my Yamaha XJ. To get it off, leave the forks mounted in the triple tree but release the top pinch bolt (the one on the triple tree holding the top of the inner tube) to free up the pressure on the plug. Then I used a very large screwdriver to push down on the plug while using a small blade screwdriver to pry out the circlip. Once the circlip was out the plug can freely come out from the top of the tube. This is just a guess, but by looking at the diagram, that looks to be the same on yours.
Joe
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 08 Feb 2014 10:55 by KZJOE900.
The following user(s) said Thank You: Troyn
  • Troyn
08 Feb 2014 15:39
#621565
Thanks Joe! That sounds like it'll do it, I'll give it a try tomorrow and let you know. I appreciate the quick reply!
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
08 Feb 2014 17:25 - 08 Feb 2014 18:34
#621574
Troyn, forgot one very important point. Please remember the inner forks spring is putting upward pressure on that cap. So when you push it down with the screwdriver you are compressing that spring. So once the circlip is out, be careful it doesn't fire the plug at you . Don't put your face in its path. Don't ask me how I know, LOL.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 08 Feb 2014 18:34 by KZJOE900.
  • Troyn
09 Feb 2014 06:35
#621640
Thanks, I'd like to avoid experiencing that first-hand!
  • Troyn
12 Feb 2014 16:20
#622044
Btw that worked, thanks! Weird way to do it I think...
  • KZJOE900
  • KZJOE900's Avatar
  • Administrator
  • Administrator
    Super Users
12 Feb 2014 18:39 - 12 Feb 2014 18:41
#622055
Troyn, my apologies but another thing I forgot to mention. Probably cause I haven't got around to reassembling mine, LOL. I think it is recommended that you replace the circlips with new ones for safety's sake. See what your service manual says on the topic.
76 KZ900
82 XJ550R SECA
Past:
86 FJ1200
74 Z1900
72 CB450
Last edit: 12 Feb 2014 18:41 by KZJOE900.
  • Troyn
13 Feb 2014 06:22
#622086
Thanks Joe, my manual doesn't say anything including how to remove the cap in the first place! They came out clean so I'm going to have faith they'll hold. :)
  • Trotskie10
  • Trotskie10's Avatar
13 Apr 2020 14:28
#823268
Hey how did you get the black "air" fitting off the top of the fork? It feels very tight and I am afraid to take it off. I am waiting for USPS to find my manual that they lost...
  • Scirocco
  • Scirocco's Avatar
  • Premium Member
  • Premium Member
13 Apr 2020 15:03
#823269
Black air Fitting? Do you talk about the air valve cap? Pics?
  • Trotskie10
13 Apr 2020 15:20
#823270
It was the two round air valves shown in the center of the screenshot. I just pulled up hard and they came off. My bike had a Vetter fairing on it, so I think it is missing some of the washers, and fittings on it. The two fittings have O-rings on the inside of them. My bike had a clamp holding the air fittings in place instead of the factory fittings that would be on it if it had headlight ears and such. I hope my manual gets here been waiting for weeks. USPS is holding it hostage I think.
