How to take the gas tank off a 80 kz1000 ltd
  • 80kz1000ltd
  • 80kz1000ltd's Avatar Topic Author
27 Jan 2014 10:09
#620240
Hey guys, just trying to figure out how to take the tank off this kz1000 ltd, just need to know how?
Thanks
  • roy-b-boy-b
  • roy-b-boy-b's Avatar
Re: How to take the gas tank off a 80 kz1000 ltd
27 Jan 2014 14:15
#620262
Pull tank to the rear a couple of inches then lift the front of the tank.
The following user(s) said Thank You: Cabbagio Redentor
  • jeffasaki
  • jeffasaki's Avatar
27 Jan 2014 14:59
#620264
roy-b-boy-b wrote: Pull tank to the rear a couple of inches then lift the front of the tank.
youre gonna need a hacksaw,a grinder and a hammer :silly:
its really very easy
78 Z1R
78 KZ1000
76 KH500 gone
71 HS1B 90
81 GS 1100 gone
80 PE400
02 KLR
Ontario Canada
  • roy-b-boy-b
27 Jan 2014 15:12
#620265
Well, just pull it back as far as it will go and lift the front. I got a friend that can't take a tank off a ltd. I have showed him 50 times at least. :lol:
  • 4TheKZ1000
  • 4TheKZ1000's Avatar
27 Jan 2014 15:14 - 27 Jan 2014 15:15
#620266
Take off left side cover or petcock will scratch the crap out of the front of side cover.
If you lift the back of the tank to high, the front top of gas tank can hit steering neck and possibly chip the paint on front seam of gas tank.
Just pay attention to both ends.
Last edit: 27 Jan 2014 15:15 by 4TheKZ1000.
  • TexasKZ
  • TexasKZ's Avatar
27 Jan 2014 16:00
#620269
You may also want to
remove the seat
disconnect the fuel line, vacuum line and fuel level wires
before tying to yank off the tank.
:whistle:
  • pete greek1
  • pete greek1's Avatar
28 Jan 2014 08:54
#620341
there is also a rubber strap that needs to be pulled off before the rear of the tank can be lifted off the frame
  • martin_csr
  • martin_csr's Avatar
28 Jan 2014 17:26
#620391
If it's a nice tank, you might want to drain it first.... fuel slosh can make the tank unwieldy. And you could put a thick towel in front of the tank to avoid contacting the triple tree n stuff as you lift it off the bike..
  • roy-b-boy-b
28 Jan 2014 17:46
#620394
Save this as a sticky !!! :woohoo: :S :S
