Front brake caliper
  • Mark Stark
  • Mark Stark's Avatar Topic Author
Front brake caliper
19 Jan 2014 14:56 - 19 Jan 2014 16:56
#619193
Hey guys! my name is Mark and I own a '79 kz650. I'm having a problem with my front brake caliper. the caliper threads are bald so my banjo bolt just slides in and out. Can you guys help a fellow KZ lover out?
1979 Kawasaki KZ650
Stark Industries
Last edit: 19 Jan 2014 16:56 by Mark Stark.
  • Nessism
  • Nessism's Avatar
Re: Front brake caliper
19 Jan 2014 18:12
#619230
I'd hit ebay or the Parts Wanted forum and look for a new caliper.
  • baldy110
  • baldy110's Avatar
20 Jan 2014 08:44
#619278
I got a caliper pay for shipping.
  • DOHC
  • DOHC's Avatar
  • Those Doe-Hawks really go!
20 Jan 2014 15:06
#619322
Mark Stark wrote: The caliper threads are bald so my banjo bolt just slides in and out. Can you guys help a fellow KZ lover out?
You could replace the threads with a helicoil or timesert insert.
www.helicoil.in/
www.timesert.com/
Ive use the helicoil kits. They come with the tap and install tool, are easy to install, and worked well. As long as there is enough material to drill a larger hole, I've heard people claim the helicoiled threads are stronger than the original aluminum threads.
My dad's '74 Z1
'00 ZRX1100
20 Jan 2014 15:41
#619328
I would replace the caliper. You don't want to take the risk of any potential brake line leak or you could get hurt. Ed
  • Mark Stark
24 Jan 2014 06:52
#619880
hey dohc! yeah I got some helicoils the other day but I still need to get the drill size. I now the banjo bolt is 7mm so would I have to drill out the new hole to 8mm? that's the size of helicoils I got.
1979 Kawasaki KZ650
Stark Industries
